Sony Ericsson / Sony : UMTS / 3G : using normal headphones with a z1010
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > using normal headphones with a z1010 Bookmark topic
jcwhite_uk Posts: > 500
The P910i also picks up automatically and then hangs up as well when used with a 2.5mm to 3.5mm converter.
The reason for this is that the headset supplied has a answer button built in. When you connect a normal pair of headphones the phone thinks the button is permanently pressed so will answer then hangup as if the button had been pressed.
Posted: 2005-04-20 13:35:25
mmsman Posts: > 500
i can't really remember this.... i had a z1010 some while ago but i can't remember experiencing such a thing, anway i'm 100% that p800 and p900 didn't had this problem but i can't say for p910 as i haven't owned one....
Posted: 2005-04-20 14:26:42
My P800 had the same problem. All p series use the same headphones so the problem is the same across the range.
Posted: 2005-04-20 15:18:21
