Sony Ericsson / Sony : UMTS / 3G : Debranded my V800 to a Z800, but not is all as it seems
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > Debranded my V800 to a Z800, but not is all as it seems Bookmark topic
gbrooks3 Posts: > 500
Not likely, without knowing what has happened i guess that he has accidently flashed incorrect files, but we need to see those names
Posted: 2005-07-27 15:15:45
Gabster Posts: > 500
Ok did the master reset, and nothing has changed (apart from losing my contact! ). I used Total Multi Server, no problems with the installation as far as I could tell. I downloaded the file Z800i_R1AB014_ZONE_1_EU-EMEA.V8S
Is that the right file? Voda still thinks that my phone is a z800i because i am unable to view their live portal correctly...no 3G available (apart from video calls).
I have taken photo's of the phone if you want I can upload it for you
[ This Message was edited by: Gabster on 2005-07-27 15:53 ]
Posted: 2005-07-27 16:50:16
Strider420 Posts: 112
It all sounds very strange, what language pack did you use?
Could you post screenshots of the phone showing the live! button and other Voda branding?
Posted: 2005-07-27 17:44:52
sapporobaby Posts: > 500
I do not think you completely flashed the phone dude. I used Davinci and used the R1014B and all the Voda-crap stuff is gone. Can you flash again?
Posted: 2005-07-27 17:46:09
As i suspect, you only flashing 1 file. SEMC firmware consists of main firmware and of FS. I guess you flashed fs only..........download both file then flash both at the same time with finalization.
Because the platform sends bogus messages while charging, that is why!!!..But why this change of heart?..We sense a charger connected, oops, we will not shut down after all!!!..*********************** UI BASIC, HOLD YOUR HORSES
[ This Message was edited by: gbrooks3 on 2005-07-27 16:51 ]
Posted: 2005-07-27 17:50:30
Vlammetje Posts: > 500
Indeed, look at the image below mate, I've highlighted the two types you need to get, just select whichever files are applicable for your situation. Gonna cost you an extra credit I'm afraid but that cannot be helped, you need to flash both files at once.
Posted: 2005-07-27 18:24:24
Thank you all for your help, very very grateful!
Posted: 2005-07-27 18:30:30
is there a known solution yet to use the 3G services e.g. download video's using a Z800 phone?
Posted: 2005-07-27 18:35:31
thegetti Posts: 20
I have just flashed my Z800 with V800 firmware. All seems to work now.
Managed to buy a wallpaper and news info from Heat. However on full tracks and video downloads it comes up with Download Failed. Might just be becasue there is a problem at the moment
Posted: 2005-07-27 20:20:43
If you mean Vodafone Live then no, there is no 100% fix. Some things will work, others won't. the portal will tell you your phone is not supported or has no UMTS coverage.
Some pages will load, some downloads will work, others won't and never will.
On other networks I don't know
Posted: 2005-07-27 23:11:04
