Manufacturer Discussion : Nokia : Nokia Lumia 620 Thread And Discussion
< Esato Forum Index > Manufacturer Discussion > Nokia > Nokia Lumia 620 Thread And Discussion Bookmark topic
Page <  123 ... 101112 ... 181920>
Bonovox Posts: > 500
Not sure what's going on there. Maybe wait a bit. I can see it there and have it on my phone now.
Posted: 2013-03-30 14:11:00
Rookwise Posts: > 500
Nah I can't get it. Still throwing up errors when I try and download it. Can't even see it on the app store now. Only the Drive+ beta and that wont even download either.
Music player is very similar to the old Xperia X10 version before the update. Can't make playlists unless its plugged into a pc. Gonna have to look into doing that sometime. Its a pain just having one album to listen to when driving. I like a long playlist.
Getting there slowly. Am liking the feel of WP8 overall and the phone itself.
[ This Message was edited by: Rookwise on 2013-03-30 14:40 ]
Posted: 2013-03-30 15:39:30
Cool. There are one or two small annoying things with WP but nothing too bad. The music player i like with full screen background for album art. But in WP8 some album art is missing but there is MPAtool for that. There's improvements all the time but at least they got rid of Zune that was for WP7.5/8 now is just drag n drop. As with all OSs there are annoyances like the EQ and audio settings are in settings and not the player itself. And the media volume is same as ringtone volume but promises of these things to change soon.
Posted: 2013-03-30 16:29:00
The music quality is ok with me. Just had the phone linked to my stereo with Evenescence playing and it sounds fine apart from a short sound when it changes tracks.
Here is what I get when trying to download Nokia/HERE Drive/Drive +
According to Nokia. The app is sim dependant depending on the sims country origin. Mines O2 UK so I wouldn't have thought it would be a problem.
Posted: 2013-03-30 17:15:28
Did you try downloading it over Wi Fi then?? I never knew or even heard of that before sim dependant. I just did a test and deleted mine and reinstalled it fine. Maybe try connection via Wi Fi.
Material things don't matter,but Rock n Roll does!!!!
Nokia Lumia 620
AKA,Bonovox
[ This Message was edited by: Sean72 on 2013-03-30 18:15 ]
Posted: 2013-03-30 19:10:00
Am only using wifi matey. I havent got a mobile data tariff anymore.
EDIT.
Just turned mobile data on and tried it that way and still got the same error message
[ This Message was edited by: Rookwise on 2013-03-30 18:45 ]
Posted: 2013-03-30 19:42:06
Posted: 2013-03-30 20:23:39
hihihans Posts: > 500
Nokia Here and Drive have disappeared from the store. Usually that means a big update
Posted: 2013-03-31 22:27:00
Cheers. I'll hold out for a bit. Hope I can get it. The nav app on android was one of my most used so could do with one.
Trying to decide what colour battery cover to get. Green,yellow or cyan. From the same place as Bonovox got his from. They also do the genuine bumpers as well.
Posted: 2013-04-01 00:36:02
The orange one i want but cannot find it. The green and orange is glossy the rest are matte. Yes apps that vanish normally means an update though is a little odd way of doing it.
Posted: 2013-04-01 01:32:00
