Sony Ericsson / Sony : Software, Firmware and Drivers : C905 CamDriver Modded
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > C905 CamDriver Modded Bookmark topic
Page <  123 ... 103104105 ... 291292293>
anouk82 Posts: > 500
On 2009-08-25 23:12:24, Theliel wrote:
most probably are that problem are in GDFS, and I suppose you dont have a backup of your GDFS.
Anyway you can try other options:
a) Change your language and back again to your default language
b) make a master reset
Anyway, im searching where are exactly the problem
i'm testing your first option....nothing i am going re-install the firmware
[ This Message was edited by: anouk82 on 2009-08-25 22:20 ]
Posted: 2009-08-25 23:18:25
Theliel Posts: 16
Sorry them. I will need much more time to check GDFS and other possibles files.
Posted: 2009-08-25 23:27:20
DarKMaGiCiaN Posts: > 500
here is my beta driver
DarKMaGiCiaN 3.11
http://www.2shared.com/file/7377568/19667af1/camdriver0311.html
it is DarKMaGiCiaN 3 with some changes regarding to your request all ^_^
more details from you = improvment to the driver ^_^
Posted: 2009-08-26 00:06:11
witchking Posts: 234
Hi all. I'll check the LNG file today and post the correct one if this is faulty. This one worked fine for me.
Posted: 2009-08-26 02:39:44
kazaf Posts: 16
DarKMaGiCiaN 3.11
wow......
can you tell us what's the difference between your 3.0 and this ver?
[ This Message was edited by: kazaf on 2009-08-26 02:13 ]
Posted: 2009-08-26 03:11:54
rajac Posts: 76
DarKMaGiCiaN 3.11
wow......
I'll try it and tell you.Maybe DM gave us a surprise.
Posted: 2009-08-26 03:43:58
brazzuka's Posts: > 500
Sample Pic
ahhh colors colors
[ This Message was edited by: brazzuka's on 2009-08-26 03:31 ]
Posted: 2009-08-26 04:23:13
On 2009-08-25 22:05:48, rajac wrote:
On 2009-08-25 21:56:47, Theliel wrote:
Fixed, sorry, the link was bad.
2s... im sure its possible add other second more. Default are 1/1, but its easy change. Anyway, taken any photo to 2s you will need a tripod.
The tripod is not the problem.Maybe I have iron hands?
Anyway,I can get more beautiful night view with 2s...
@rajac
Simple see the camdrivers with manual shutter fast/slow and add 2s in your driver buttt the true manual shutter speed fast/slow
@Theliel
correct arguments
Good job guys!
Posted: 2009-08-26 04:36:43
kazaf Posts: 16
@brazzuka's
you tested DM3.11? me too ....
when I take a night mode photo..I can feel that the shutter speed is obviously much more slow
but when I put the photo into pc
it's show that just 1s exposure
do you got the same case?
COOOOOOL!!
I DID IT...
The part of "Effects", I changed it to "ISO" "ISO 100"......
Its match with DM 3.0 camdriver
AND I TESTED IT ALREADY....IT WORKS ON MY PHONE
ENJOY YOURSELF!!
BEWARE: MY FIRMWARE IS "R1FA035"
I don't know does it suitable for all ver.
PLEASE DO A BACKUP WITH YOUR OWN "en.lng"
Download and place the file in tpa/preset/system/language
http://www.2shared.com/file/7384042/5dab0bb9/en_online.html
@DM
Im using your 3.11
sometimes even I lock ISO to 400 or 200 or 160
then I take a shot
but found out ISO let say is just 64 even I choose different ISO level
what's wrong with this matter?
can i force it to ISO 400, 200, 160?
also, the longest exposure time of your 3.11 is 1s?
haha ~ can you release a 2s ver.?
really thanks
[ This Message was edited by: kazaf on 2009-08-26 08:33 ]
Posted: 2009-08-26 05:14:41
mazi292 Posts: 38
DarKMaGiCiaN is your best camdriver what you did.
Is great, because the colors are naturale earlier were white with blue flash.
Posted: 2009-08-26 12:55:12
