Sony Ericsson / Sony : Software, Firmware and Drivers : Phone Flashing Tutorial XS++
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > Phone Flashing Tutorial XS++ Bookmark topic
Page <  123 ... 121314 ... 293031>
bojanbl Posts: 3
Thanx but can I make backup of my original firmware? How to backup menu.ml and all other system files?
Posted: 2008-04-10 14:26:43
strizlow800 Posts: > 500
Here is a copy of original generic K800 menu.ml
http://rapidshare.com/files/106355487/MENU.ML.html
Posted: 2008-04-10 14:34:53
alfath Posts: 74
u can use main2raw and sefstool to create a backup for file system i guess...
by the way, can i use xs++ to flash and modify W810? if it can, is the procedure like flashing K800?
Posted: 2008-04-10 19:27:08
tranced Posts: > 500
of course my mate
Posted: 2008-04-10 20:17:04
alfath Posts: 74
@tranced
thanks a lot bro, i just wondering if i play with another phone maybe i can get those nerveous feeling like the first time
Posted: 2008-04-11 23:27:56
razon1994 Posts: 1
SOMEONE HELP ME PLS...
my k800i after flashing, when i on da phone,
it says ''insert the correct sim card'' ,
wat should i do?!
Posted: 2008-04-13 04:45:19
You have to apply the unlock patch on your phone...
Posted: 2008-04-13 09:10:36
o166 Posts: 32
Hi all, is the guide applicable to all other SE phones? Because the phone use as the example in this guide is W300. How about other SE phones, is the process the same?
Posted: 2008-04-14 02:05:31
this method is only possible with phones that are db2010 and db2020 and CID36/49/51/52.
Posted: 2008-04-14 02:22:34
o166 Posts: 32
@tranced
that should answered my question, thanks a lot
[ This Message was edited by: o166 on 2008-04-14 01:39 ]
Posted: 2008-04-14 02:38:30
