General discussions : Rumours : P700 is on its way
> Topic Locked
Esato Forum Index > General discussions > Rumours > P700 is on its way Bookmark topic
Page <  123 ... , 128129130>
Jah Posts: > 500
@mib1800
re: CPU speed & graphics etc
it is odd that downloaded videos from www.bbc.co.uk run more smoothly and look better quality on my M600 then on my N95...perhaps the screen resolution and colour density also has an impact on the end user experience. As usual theory and real life never seem as consistent as they should be...
Posted: 2007-05-07 13:13:47
razec Posts: > 500
To mib1800:
how can you tell N95's graphics processor was better than P700 or the current UIQ phones whist we don't know the clock speed of these chipsets? AFAIK UIQ's transition effects was more graphics hungry than N95's transition effects and both the phone chips were not having it's own RAM so how can it become better than UIQ 3s?
Posted: 2007-05-07 13:15:06
mib1800 Posts: > 500
@razec
no idea. I am just basing it on peter kay's thread which says the p700 has the same processor speed and lite version of graphic processors. From Jbenchmark Pro (jbenchmark.com), N95 has a benchmark result of 400+ whereas m600/p990 is about 220. This should give some indication (but not absolute) of the performance difference.
Posted: 2007-05-07 14:07:37
londonlad123 Posts: > 500
Yes the n95 has a more powerful processor and graphics ability than the p700 or so it seems but the question is, is this a good idea?
But do we really want less battery power and a more expensive device to play the ngage gaming deck.
Posted: 2007-05-07 15:25:19
Dogmann Posts: > 500
Hi all,
Well as the processor and graphics chip are the same as in current UIQ3 devices it does make a lot of difference the first being something that so many of you seem to want the ability of to be able to record @ 640x480 30fps VGA video as this is dependant on the graphics chip and the reason the UIQ3 devices don't is the fact they have the lite version of this chip.
I find Jah's comment of video looking better on the M600 quite strange as both my now sold N93 and now E61 are definitely much better than the M600 i had. But as i am about to purchase a UIQ3 device shortly I will test them head to head with the E61 just to see what results it produces.
Marc
Nokia E61 2gb Sandisk, Fring, Tom Tom 6, AD-46 with Black Shure EC2g
[ This Message was edited by: Dogmann on 2007-05-07 14:39 ]
Posted: 2007-05-07 15:38:11
masseur Posts: > 500
are you running the latest unbranded N95 or an original version, branded one?
I've just done a comparison of M600 vs N95 on the BBC site, after restarting both phones, and find the N95 to be quicker and smoother. I do have a 2gb memory card with about 200mb free though I'm not sure if thats being used or internal memory but...
On 2007-05-07 13:13:47, Jah wrote:
@mib1800
it is odd that downloaded videos from http://www.bbc.co.uk run more smoothly and look better quality on my M600 then on my N95...perhaps the screen resolution and colour density also has an impact on the end user experience. As usual theory and real life never seem as consistent as they should be...
Posted: 2007-05-07 15:39:32
DragonEye Posts: > 500
On 2007-05-07 06:17:22, mib1800 wrote:
ares
mib1800, agreed, but in the p700 vs n95 case the processor is not 2 times more powerfull AFAIK...
It is about 1.3 times more by processor speed but taking into account better graphic processor of N95 it may be more. With the current RAM level of N95 only under a few occasion (like surfing to huge web page and having Gallery open at same time) then you may hit memory full. So 80-90% of the time you can use it to full speed potential.
The P700 advantage is that you never have to worry about "memory full" again. But under most normal usage scenario, it will most likely to perform slower than N95 esp. in multimedia intensive ops like UI, video playback or surfing the web.
[ This Message was edited by: mib1800 on 2007-05-07 05:23 ]
first.... are processors always running at top speed? That doesn't seem to make sense... like a pc it runs faster as more resources/processing power is needed....
second you're excluding UI design... take the k790a for example it's gallery destroys my n95 in start up and image population.
surfing the web is not a heavy processor based application.....ram is more important for web surfing....
Posted: 2007-05-07 16:27:21
Jah Posts: > 500
@Dogmann
sorry to cause a mild panic, the video playback in general of the N95 is far superior to the M600. I was just surpised there was such little difference when I was watching videos from the BBC web site. Now that I have thought about it a bit - its a encoding issue not a rendering/playback issue
@Masseur, just tried again as I upgarded the FW a few days ago. You are right the playback is better. But as stated above, video in general is superb on the N95 and the video recoding means you really don't need a camcorder anymore
Sensibility resumed....
Posted: 2007-05-07 16:49:48
dragonEye:
You cannot compare this way. K790 gallery is much more simplistic than the N95 gallery in outlook and effect. Try installing RescoViewer (a simplistic photo viewer like those in SE) and I am pretty sure N95 beats the K790 in speed. btw: in the new firmware the N95 gallery is faster and smoother without lag.
Surfing the web IS very processor intensive with wifi/downloading and the display of images and running of scripts. You can even feel the battery becoming hot.
Posted: 2007-05-07 17:16:12
>500 Posts: > 500
guys can we stick on topic please..... its a RUMOUR thread..... no comparisons needed..... shouldnt be any comparing anyway as the phone hasnt even been announced yet if you have info about the phone, great, lets hear it! if not, well then...... these rumour threads have enough off topic comments in them as it is.....
formerly known as ads1107,jedi-master... but still, may the be with you!
[ This Message was edited by: >500 on 2007-05-07 16:21 ]
Posted: 2007-05-07 17:19:58
New Topic   Topic Locked
