Sony Ericsson / Sony : Software, Firmware and Drivers : Phone Flashing Tutorial XS++
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > Phone Flashing Tutorial XS++ Bookmark topic
Page <  123 ... 131415 ... 293031>
tranced Posts: > 500
afaik, you own a k800. there's no problem using xs++ with your phone.
Posted: 2008-04-14 05:05:59
strizlow800 Posts: > 500
K800 all operations tested and working with XS++ and this tutorial
Make sure you have latest XS++
Posted: 2008-04-14 14:15:49
o166 Posts: 32
another question, what is the 'Select CDA and region' means'? Is it possible for me to just select any CDA or do I have to select the exact same CDA as my phone?
Posted: 2008-04-14 15:43:20
it's better to select the correct region as it wont make any problem with the languages.
Posted: 2008-04-14 17:36:31
whiteman Posts: 4
Hey can any plz tell me where i can find a custpack for a K800 CDA102511/69
[ This Message was edited by: whiteman on 2008-04-17 06:10 ]
Posted: 2008-04-17 06:25:59
whiteman Posts: 4
Hey can this Custpack EUROPE_1 (CDA102511/89) (K800)
Generic(non-branded) custpack: Yes
Allowed languages: en, pt, es, fr,
work with my " CDACDA: CDA102511/69 R14A" ???
Posted: 2008-04-17 07:05:29
yes it will.
Posted: 2008-04-17 09:21:42
whiteman Posts: 4
thanks a mill
Posted: 2008-04-17 09:56:58
o166 Posts: 32
one more question, i want to convert my k610 to w660, so should i choose custpact k610 or w660?
Posted: 2008-04-17 12:35:11
You should use w660 custpack. Anyway as far as i know you will have problem with the walkman player and the display. Display problems can be solved with putting a w660 disp driver in it, but if you want to run walkman, you murt have the facewarp app running and minimized...
Posted: 2008-04-17 12:44:17
