General discussions : Rumours : P700 is on its way
> Topic Locked
Esato Forum Index > General discussions > Rumours > P700 is on its way Bookmark topic
Page <  123 ... 141516 ... 128129130>
sosojerk Posts: 295
@cristiano:
why do you ask him the same questions over and over again?
No GPS and no HSDPA either.
It was mentioned before already.
Posted: 2007-04-12 19:07:46
londonlad123 Posts: > 500
On 2007-04-12 18:46:45, DocTorpor wrote:
It did have a very good FM+RDS radio with a very nice interface.
The silver bar between the screen and keyboard (as shown in the front-housing picture) was covered by a (temporary?) black plastic bar with the prototype assignment 'SE123' printed on it.
Thanks! It is good to hear that is does have FM Radio! I thought they wouldn't take FM radio seriously anymore, but its good that they did. Sounds pretty much like its a p990 in a M600 body with more improvements.
If Lizzy is cancelled, I wonder if there is going to be another UIQ smartphone without a camera? Or the m600 is going to run for longer?
In the model you have seen is the internal memory for the user and the RAM being used as one?
Posted: 2007-04-12 19:15:56
cristiano Posts: > 500
On 2007-04-12 19:07:46, sosojerk wrote:
@cristiano:
did i asked you ??
i said DocTorpor not sosojerk
and if a mid range mobile had HSDPA why won't a high-end one not having this feature?
Posted: 2007-04-12 19:19:05
DocTorpor Posts: 107
Sorry cristiano, like sosojerk already summarized, I haven't found any proof of HSDPA or GPS in the acceptance-sample I saw. I hoped to find HSDPA as well.
I prefer my GPS to be an external one via BT with the GPS having its own battery.
Speaking about batteries: I noticed there was a BST-33 950mAh in the sample-unit.
The same one is now being used in the M600i/W950i. So I can't confirm the previous rumour about a 1250mAh one in Elena:-(
[ This Message was edited by: DocTorpor on 2007-04-12 19:00 ]
Posted: 2007-04-12 19:56:34
deuxani Posts: > 500
@DocTorpor, I wish I had seen it.... Maybe you could help me with that...
@Jedi-Master, here you go
Posted: 2007-04-12 20:13:44
where's the speaker??
Posted: 2007-04-12 21:09:50
The speaker was very cleaverly hidden under a shiny silver horizontal bar above the camera. Both the silver top-edge and the piece of black directly above the cam were just dipping inwards 1mm or so on both sides of this bright silver bar, leaving speaker holes of approx. 1mm in depth and 1mm in width on both sides. The silver bar itself was flush with the rest of the housing. (-deuxani?- you gave this horizontal bar a gradient already).
Both the full-width speaker openings were covered by the same sort of cloth used on the speakeropenings on the M600i. With this handset, the color of the cloth was black.
The speaker was very loud!!!
@deuxani: again, well done! If I remember correctly, the SE branding on the backside had the same orientation, but was at the left side. At the location where you put the SE logo now, there was room for the modelnumber (SE123 in my case)
Posted: 2007-04-12 23:41:51
@deuxani
Another noticeable feature on the housing was a protruding silver eye where you could attach a lanyard. It was located above the jogdial at approx the same height of the silver speakerbar on the backside.
Compared to my M600i the jogdial on the test-sample was smaller in diameter, but there was no plastic 'protection buldge' obstructing its use. I liked that one better than the one on my M600i.
All in all I think SE took notice of the many different complaints that arose from SE smartphone users and addressed many of the issues in this device: better screen, more memory, better jogdial, louder speaker, no more static in music, updated wifi and cam,...= solid evolution to me! (subjective)
[ This Message was edited by: DocTorpor on 2007-04-12 23:04 ]
Posted: 2007-04-13 00:02:02
rambo47 Posts: 247
Anybody care to speculate on how soon I can have one in my grubby little mitts? I'm getting very excited about this mobile. It almost sounds as if SE has been listening to all my little gripes and likes and decided to design this phone just for me!
Posted: 2007-04-13 02:52:26
Gok Posts: 77
someone should setup a contest. Anyone willing to enter wil pay a $0.50USD fee, and anyone who guessed the correct release day will get the price.
Posted: 2007-04-13 03:12:08
New Topic   Topic Locked
