Manufacturer Discussion : Nokia : Nokia Lumia 620 Thread And Discussion
< Esato Forum Index > Manufacturer Discussion > Nokia > Nokia Lumia 620 Thread And Discussion Bookmark topic
Page <  123 ... 151617, 181920>
hihihans Posts: > 500
To go back to topic, @rookwise what is your conclusion after using 620 a few days?
Posted: 2013-04-07 10:25:00
Rookwise Posts: > 500
After a week. I'm still finding things out on how the phone works. Some things like making playlists are long winded doing it on the phone but takes seconds via plugging the phone into a computer. Ringtone maker isn't needed. You can just connect the phone to a pc and goto the phones internal memory. Copy the file you want as a ringtone over to the ringtones folder and its all done.
+'s
Phone is a nice size and weight
Screen is nice and visable
Memory card expansion
Camera button
Customisable covers,layout and tile colours
Loud speaker. Easily hear the phone ringing and watching youtube vids sound really good
Loud earpiece
Good wifi range
Decent camera
-'s
camera lag when taking a pic
internal useable memory is write protected so cannot delete files moved over to playlist folder
to remove the battery cover you have to press on the canera/flash lens area
battery can drain quickly
Possibly more things I could add but can't think of anything atm
Posted: 2013-04-07 23:19:18
Bonovox Posts: > 500
I find battery is good easily lasts a day. That camera shutter delay mostly happens when you take a first photo after opening camera. The remaining photos afterwards are not as slow which suggests a bug
[ This Message was edited by: Bonovox on 2013-04-07 22:29 ]
Posted: 2013-04-07 23:27:51
I find the camera lag happens mostly when the flash is used. The battery is good and does last a day with light use but it could be better imo. Basically like my SGS2 was with the standard battery. An extended battery would be nice but again it just depends on usage.
Deffo not knocking the phone at all. I'm liking it a lot and is much more comfortable to use over my SGS2.
I think the keyboard needs bigger keys as well.
Posted: 2013-04-07 23:35:08
The Windows phone keyboard is a great typing experience though. There is a fix for the camera bug and other general stuff coming soon. On standby and general usage battery lasts good but like most phones alot of video or browsing will drain it faster. One thing MS changed in WP8 is keyboard layout slightly different. The comma key next to space bar i keep knocking the comma key all the time and having lots of commas in parts of sentences where they shouldn't be
Material things don't matter,but Rock n Roll does!!!!
Nokia Lumia 620
[ This Message was edited by: Bonovox on 2013-04-07 23:41 ]
Posted: 2013-04-08 00:33:00
OTA update released today for UK handsets.
Phone has become more responsive and faster through menus. System settings also has a new option of Storage Check where you can view the phones storage and clear temp files.
Under the Extras+Info menu I have the following:
Accessories agent: 1.0.5.2
Feedback to Nokia: 2.3.0.10
Nokia first user experience: 1.5.1.1
SMS Vcard receiver: 1.1.0.4
Warranty registration: 1.1.0.4
SIM Unlock: 1.0.0.5
Manufacturer Model Name - RM-846_eu_euro1_267
Mobile Operator Name - 000-GB
Configuration ID - 147069
Label ID - 1030.6407.1308.10133
Under the About menu via the More Information tab:
OS version: 8.0.10211.204
Firmware revision number: 1030.6407.1308.0002
Hardware revision number: 1.0.0.0
Radio software version: 2.0.242008.6
Posted: 2013-04-10 19:31:56
Mine not updating
Posted: 2013-04-10 19:36:57
[ This Message was edited by: Rookwise on 2013-04-10 18:46 ]
Posted: 2013-04-10 19:45:17
There is supposed to be camera quality improvements too. Oh damn wish i never had a branded one
[ This Message was edited by: Bonovox on 2013-04-10 18:49 ]
Posted: 2013-04-10 19:47:45
My latest creation But I should have reduced the animated area of the bloke and buildings before uploading as it looks like there is an earthquake with them buildings shaking
http://memories.nokia.com/en/[....]3a-d2a4-406d-9947-e03f00f8b798
[ This Message was edited by: Bonovox on 2013-04-10 20:38 ]
Posted: 2013-04-10 21:37:17
