Americas
FroYo en mi G1:
Posted: 2010-07-12 23:11:55
Opera Mini 5.1 for Android released
Oslo, Norway — July 14, 2010
Opera spreads the love to Android mobile phone users. Opera Mini 5.1 is now available for phones built on the Android platform, offering better browsing performance and improved user experience.
With over 61 million users worldwide, Opera Mini is the world’s most popular browser for mobile phones, allowing much faster browsing speeds, while keeping the costs to a minimum. Browse at lightning speed today by downloading the free Opera Mini browser from the Android Market or at m.opera.com.
Opera Mini is a favorite not just on feature phones, but also on smartphones, scoring an impressive 1 million downloads on the iPhone during the first 24 hours of availability. Opera Mini is highly optimized for almost any handset, delivering the best Internet experience on more than 3000 mobile phone models.
Opera Mini raises the game on Android phones. Since its Opera Mini 5 beta release, Opera Mini can now be set as the default browser for more convenient Internet access. Opera Mini 5.1 also offers improved page layout on high-end Android handsets with large screens.
Posted: 2010-07-14 16:55:55
@grafy: ke ROM/Firmware o como se llame tu le tenias al Moto Cliq, o cual es el ultimo? el Eclair(2.1) o el Froyo(2.2)??
- otra pregunta, a ver si entiendo, usare ejemplo a SE
ROOT es como si fuera los customs, camdrive, acoustic, patchs y demas chucherias?? Y
FLASH es pa los Firmwares: MAIN y FS, ej.: Android OS 2.1??
- Segun taba viendo orita el xda-dev team no embroma con el cliq, porke no es HTC...
.. solo esta pagina vi ke embroma con el moto cliq:
modmymobile , alguna otra mas?
- Hay alguna forma de Unlock permanente el moto cliq, gratis? rootiandolo o como?
... no mas preguntar por ahora.
pd: manana es ke recibire mi Moto Cliq
pd2: kiero Froyo...
[ This Message was edited by: adhgklk on 2010-07-15 03:42 ]
Posted: 2010-07-15 04:32:57
@adhgklk: la ultima version de Android es la 2.2 aka FroYo(Frozen Yoghurt).
El root no es mas que la opcion de hacer lo que tu quieras con tu telefono android. Bueno, es aprovechar un agujero que tiene la version 1.5 y anteriores. A partir de ahi puedes instalarle diferentes ROMs(firmwares en terminos de
). Esos ROMs son las mismas versiones de Android pero modificadas.
Posted: 2010-07-15 04:49:30
@Tranced: el froyo es el ultimo update a oficial, pero no estaa para todos los android.phones, como el Moto Cliq el cual esta esperando de hace tiempo a Eclair(2.1) final y no llega... espero ke la tiren pronto y ke sea a Froyo en vez de Eclair,
entonces a ver si entendii, solo se puede ROOTear de la version 1.5 pa abjao(1.4, 1.3, etc)...NO pa arriba(1.6, 2.1, 2.2..)??
pd: tienes suerte de ke el G1 sea HTC, osea, ke el xda-dev team le da soporte...
Posted: 2010-07-15 05:07:33
AReGo Mp3 Downloader
Es como un Ares o Limewire pero en tu movil, sirve pa descargar mp3 facilmente.
Pag oficial:
http://sviudes.blogspot.com/2010/04/arego-mp3-downloader.html
Link de descarga (PC):
http://www.box.net/shared/i7l7xmyy9m
QR:
Posted: 2010-07-15 05:45:47
pd2: kiero Froyo...
oye mano lamento decirte que el cliq lo dejaron hasta la version 1.5 y todavia se esta esperando el update a eclair 2.1 y te digo que se puede rotear facil si no esta upgradeao, el unlock es medio carito lo tendras que comprar o ir a un centro de santiago creo q anda por los 1k....
Posted: 2010-07-15 15:16:31
Resolver la descarga rapida de tu bateria en gphones Solo telefonos Root:
antes de iniciar debes tener es adb o hacerlo por terminal emulator desde el movil:
OK, basta de charla , esto es lo que debe hacer:
1. apagar el telefono y darle carga hasta que la bateria este full .
2.
Opcion1: Inicie en modo de recuperación e ir a la consola (o "adb shell) y escriba:
1. adb devices ( debe aparecer el modelo ejemplo: G1)
2. adb shell [enter](Aparecera el Signo de #)
3. mount(space)-(space)a [enter]
4. rm /data/system/batterystats.bin [enter]
5. reboot
2.
Opcion2 es el metodo mas facil: Si no quiere hacerlo desde la consola de recuperacion vaya al market y bajese el terminal emulator o cualquiera de esos q sirvan para ejecutar comando desde el movil.... y escriba:
1. su
2. mount(space)-(space)a [enter]
3. rm /data/system/batterystats.bin [enter]
4. reboot
3. Reinicie el teléfono y descargar el telefono hasta que se apage. (Consejo: Con el brillo al maximo y el tiempo de espera siempre encendida la pantalla, si quiere le prende el wifi y el gps para que consuma mas rapido. )
4. Recarga el teléfono completamente y luego usarlo como lo haría normalmente .
Listo.....
los problemas de bateria ocurren cuando rooteamos nuetros moviles que la bateria no se calibra correctamente...con este tuto notaran la diferencia de los que les digo...
Posted: 2010-07-15 19:58:25
Excusa la ignorancia, pero cuando pones "(space)" es porque hay que dejar espacio?
Porque de ser asi hubieses dejado el espacio y ya
Gracias por el tuto
Posted: 2010-07-15 21:27:48
si a ese nivel es como se brega en Android, ya está llamando mi atención
Posted: 2010-07-15 21:32:50
