Sony Ericsson / Sony : Tips and tricks : Free Internet Browsing on Opera Mini using Proxies
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Free Internet Browsing on Opera Mini using Proxies Bookmark topic
Page <  123 ... 171819 ... 242526>
katorzingko Posts: 19
hello goarthur...so sad its not working...
i've installed it when i have a load of 10PHP then it deducts my balance...my bal. became 5php only.
and when it was already installed, i used my other globe sim with zero balance but its not working...
it always prompt me an error msg.. hayyyzzzzz so sad!
Posted: 2010-03-23 08:20:29
goarthur77 Posts: 47
@ kator5, i think by this time it should be working. you made a new connection right? that connection is the connection you should use when the operamini runs and prompts for a connection. just double check. no pain no glory. or use the sim you installed it with. your load should be less than 5pesos or zero load for globe networks.
Posted: 2010-03-23 09:41:33
i cant install it without a minimum of 10PHP load....now it exits wenever my load turns in zero bal.
Posted: 2010-03-24 10:02:34
xxambad4fellaxx Posts: 124
@katorzingko
you had P10 when the installation took place, am i right? How come you weren't able to install the om successfully? It should have been installed coz your 10 peso credit's supposed to be good for half an hour of mobile inet if you're on the time based charging.
Posted: 2010-03-24 16:06:00
Kator5, let's double check FOR YOUR PHONE
Apn : http.globe.com.ph
Proxy server name: 80.239.242.253
Proxy port: 80
FOR YOUR OPERA MINI
custom http server:
http://twitter.globe.com.ph
That's it! do not change the others not mentioned! We will change once you report to us that you can browse for free.
try to use all small letters on your settings.
Posted: 2010-03-24 17:01:55
Take it from sir goarthur. He's worth his salt. Hope it's gonna be a hit this time! Just keep on trying!:-)
Posted: 2010-03-25 02:16:00
thanks for the compliment,ambad4fella!
Posted: 2010-03-25 13:05:20
@goarthur
it's nothing compared to all the help you guys have been doing for us your fellows. You've been more than helpful to us and you deserve to be complimented. Keep on with your good work!:)
Posted: 2010-03-26 00:04:00
Hello..
To goarthur:
thank you..i can browse the internet using my phone for free, my question now is..how can i download or upload files? And how do i save images to my phone? I've tried to save images when i hit page info then 'download images' but it d0esnt work. Plz help me,thankz
Posted: 2010-03-28 07:18:57
Just look for litemint's thread about browsing and downloading via OM at the Asia Pac section.
Posted: 2010-03-28 07:42:00
