General discussions : Product reviews : what can you say about smart amazing fone?
< Esato Forum Index > General discussions > Product reviews > what can you say about smart amazing fone? Bookmark topic
Page <  123
kapitan jackal Posts: > 500
@arnoldc- just checked you LINK. do you know anyone who successfully unlocked their SPV/SAP? tia!
Posted: 2003-05-13 15:06:00
vctor Posts: 70
me! i got my tanager unlocked hehehe
Posted: 2003-05-13 20:19:00
dark_knight_r3turns Posts: 186
with d amazing fone, can u transfer pictures/audio thru IR? This message was posted from a P800
Posted: 2003-05-14 03:50:00
randyrivera Posts: 219
the spv is using the pocket pc os, it even has windows media player This message was posted from a WAP device
Posted: 2003-05-14 04:03:00
lethal_cassanova Posts: 338
kailan kaya lalabas ang smart 2003?sbi nila meron na daw blue tooth eh
Posted: 2003-08-25 15:07:37
ericharlz Posts: 67
kahit mga smart employees d pa nila masabi kung kelan.. pero nagkaroon n ata sila ng training on SPV E200 (MS Smartphone 2003) hayyyy luma n nmn pag nilabas d2 sa pinas (sabagay wala nmn ako pambili nun)
-=EC=-
Posted: 2004-03-18 17:17:12
rcperez Posts: 3
Microsoft Powered Smartphone in a nutshell
Actually, MS smartphone's ability is within the compentence of the user. MS Smartphone is very much like a PC, if the user is incompentent with his box for sure it will be slow, nerve wrecking and unreliable. But in the right hands its the most efficient machine ever and could easily "out smart" anything in the market to date. If you hear a PC user complaining that his PC is unreliable, slow or unusable chances are that user is a novice with no apprehension for technical things (And you chuckle everytime you hear it coz you know that its USER ERROR and not otherwise) well same goes true for Smartphone users.
Different strokes for different folks
Most Commonly Thought of Problems with SAP
1. High Battery Consumption (its a pda and an upgrade fixes it)
2. To many click to run an app (heard of Speed Dial???)
3. Hangs often (don't fill your IPSM fill your SDC instead)
4. Slow Response (USER ERROR like in slow PC's, just use taskmanager and file explorer to arrange your data properly)
5. USB Charger (off the shelf yes, buy a standalone charger for P150)
6. User-Enemy (well smartphones and pc are not for everyone)
Advantage of SAP over other brands
1. able to send recieve MMS to other branded cellphones
2. able to send recieve IR carriers to other branded cellphones
3. able to use WAP and Internet explorer
4. SDK for developing application is for free (develope what you want and need, you could even sell it without paying any royalty)
5. Synching with the PC is done via IR or USB (not the slow serial cable which you need to buy as an addon)
6. and very much more
Posted: 2004-04-23 08:17:42
lor Posts: > 500
We'll see how long the symbian operating systems are going to last. Smartphones running the windows mobile operating systems will only get better as time goes by. Plus many brands are already using it. Samsung, Motorola, HTC, etc.
Posted: 2004-06-01 08:07:38
Page <  123
