Sony Ericsson / Sony : UMTS / 3G : umts/wcdma difference
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > umts/wcdma difference Bookmark topic
Page <  12345>
scotsboyuk Posts: > 500
@brix25
They are more than related, GSM uses TDMA to function.
Posted: 2005-01-02 20:29:40
OluYom Posts: > 500
Guess that settles the debate then :) This message was posted from a P800
Posted: 2005-01-02 20:32:45
govigov Posts: > 500
@scots, nothing bad should be inferred. I said that because i had some doubts, you were clear on the topic. So you had to be correct.(hope you are not offended in any way) @all, what does the article say? This message was posted from a K500
Posted: 2005-01-02 20:49:22
@govigov
I just can't stand all that bally nonsense about 'veterans' and 'senior members' etc, not my cup of tea. Everyone's opinion is equally valid regardless of the length of time they have been a member of Esato or the number of posts they have.
The article explains how GSM is based on narrow band TDMA.
Posted: 2005-01-02 21:00:14
@scots, hmmm... But you are still a senior member to me :p ! @all, i meant if some one could quote the article. This message was posted from a K500
Posted: 2005-01-02 21:02:33
OluYom Posts: > 500
Now I can see how a GSM network setting up 3G requires so much funds. Its actually setting up a different platform (WCDMA) from the existing (TDMA), not merely upgrading. @scots: I imagine that 3G sets belong to those cross-platform devices you inferred, since they (3G sets) can also utilize 2G networks under certain circumstances. This message was posted from a P800
Posted: 2005-01-02 21:06:32
@aya, will pls copy paste the article here. This message was posted from a K500
Posted: 2005-01-02 21:08:31
@govigov
I shall take your comment as a compliment then, but I would rather you didn't call me that.
The article is from Howstuffworks.
Probably the most useful thing to know about the Global System for Mobile communications (GSM) is that it is an international standard. If you travel in Europe and many other parts of the world, GSM is the only type of cellular service available. Originally, the acronym GSM stood for Groupe Spécial Mobile, a group formed by the Conference of European Posts and Telegraphs (CEPT) in 1982 to research the merits of a European standard for mobile telecommunications. Commercial service using the GSM system did not actually start until 1991. Instead of using analog service, GSM was developed as a digital system using TDMA technology.
Using TDMA, a narrow band that is 30 kHz wide and 6.7 milliseconds long is split time-wise into three time slots. Narrow band means channels in the traditional sense. Each conversation gets the radio for one-third of the time. This is possible because voice data that has been converted to digital information is compressed so that it takes up significantly less transmission space. Therefore, TDMA has three times the capacity of an analog system using the same number of channels.
TDMA splits a frequency into time slots.
TDMA is the access method used by GSM, as well as the Electronics Industry Alliance and the Telecommunications Industry Association for Interim Standard 54 (IS-54) and Interim Standard 136 (IS-136). GSM implements TDMA in a somewhat different and incompatible way from IS-136. Think of GSM and IS-136 as two different operating systems that work on the same processor, like Windows and Linux both working on an Intel Pentium III. GSM systems provide a number of useful features:
* Uses encryption to make phone calls more secure
* Data networking
* Group III facsimile services
* Short Message Service (SMS) for text messages and paging
* Call forwarding
* Caller ID
* Call waiting
* Multi-party conferencing
GSM operates in the 900 MHz band (890 MHz - 960 MHz) in Europe and Asia and in the 1900 MHz (sometimes referred to as 1.9 GHz) band in the United States. It is used in digital cellular and PCS-based systems. GSM is also the basis for Integrated Digital Enhanced Network (iDEN), a popular system introduced by Motorola and used by Nextel. The incredible growth of GSM is a big part of why the acronym is now commonly thought of as standing for the Global System for Mobile communications!
[ This Message was edited by: scotsboyuk on 2005-01-02 20:12 ]
Posted: 2005-01-02 21:10:09
@scots. Yup thanks! Sure appreciate you a lot brother. This message was posted from a K500
Posted: 2005-01-02 21:19:51
walaj Posts: 11
however, UMTS actually only requires a new RADIO network - much of the "non-radio" part (known as the "Core") of a GSM network can be reused.
One of the reasons most commerical 3G networks have been so late, is because of the cross network functionality - in the handset. So (for example) the SE V800 is a dual mode handset as it supports both GSM and W-CDMA radio networks, and can handover between them (assuming this is supported by the network of course)
Posted: 2005-01-03 00:30:05
Page <  12345>
