General discussions : Rumours : Just receive new SE model - they think that it is killer )
< Esato Forum Index > General discussions > Rumours > Just receive new SE model - they think that it is killer ) Bookmark topic
Page <  123 ... , 252627>
Dyce9984 Posts: 168
I can safely say it won't be T, and I am almost convinced it will be C, almost 100% convinced it won't be K.
If you don't believe me, do your own little bit of research on the net
Posted: 2004-12-30 13:48:13
goldenface Posts: > 500
I can't seeing it being a C***.
What special feature(s) or form-factor would a new C*** have to distiguish from all the other models?
All of the other models have some feature that holds the range together, for example if it was a [K] you would expect Candybar + vid or if it was [Z] you would expect clamshell.
What would be so special about a [C]?
Posted: 2004-12-30 16:24:17
milmino Posts: 454
On 2004-12-29 21:05:51, slass wrote:
Dyce9984; That theory of yours is not really 99% correct...
Z - Viola, T - Mira, T - Nora, F - Amy, K - Alice, and so on...
as slass said before, your theory isn't completely accurate @dyce
Posted: 2004-12-30 18:05:44
FuricTrax Posts: 261
I've just had a quick flick through this post and can't see an estimated release date.
Maybe I've missed it. If so I apologise.
Does anyone have any rough ideas? My contract expires in June.
Posted: 2004-12-30 19:03:07
Memzee Posts: 399
2Q 2005 I think.
Posted: 2004-12-30 20:18:12
Dyce9984 Posts: 168
For those who have replied to my previous post. Have a look at much much older ones, and concepts that didn't get released and so on. I did say that there were exceptions and why this is usually the case
But from what I understand from what I was told, usually their intentions are to use the first letter of the code word. Untill someone online has leaked the code name, and then things change.
Why do you all think that "the only pic" of the T650 came from "that" video clip. And all sites were promptly told, not to mention the "t650" word again, nor show the picture. Then low and behold a few months later a K700i comes out looking exactly the same.
All I'm saying is think about it
Not saying I'm a know it all, and I work for SE, cause I don't on both accounts. Just passing my little 2cents
@ slass - Viola was the V800 not a Z
Or is it?...............Mwahahahaha
[ This Message was edited by: Dyce9984 on 2004-12-30 23:27 ]
Posted: 2004-12-31 00:26:34
Memzee Posts: 399
I see what you mean, but I don't really see why changing the name because of a leak would make any difference. What does the difference between K700i and T650 make to the buying customer at the end of the day? It's only a letter followed by 3 numbers (and a letter, depending on whether it's a chinese model or international).
Posted: 2004-12-31 10:43:34
bart Posts: > 500
its easyer to make the link between a Txxx phone and the next one. instead of a new line.
not many people think that the K700 is the T610/T630 succesor, neither do i.
Posted: 2004-12-31 11:49:41
Memzee Posts: 399
I agree. The T6x0 were always marketed as 'business' phones, even though they were popular with youth, whereas the K700i was actively marketed as a youth phone. Maybe it was just SE waking up to the fact that they were aiming the T6x0 at the wrong segment.
Posted: 2004-12-31 13:13:17
kenx3000 Posts: 160
I fully agree with Memzee on what you said. Note that when SE's information leaked and people were rumoring about "T650" and specification, things pretty much changed. On K700i's market at that time, there wasn't any competitor to be putting high ends specs on it at the time and put it in a mid-end market. Now Nokia 6230 and Motorola E398 came out and things changed. K700i was pretty much an experiment-model to survey the mid-end markets. SE now knows the next T series would need more guts to put up high in the mid-end market along with S700i which in near future would likely drop down to meet the mid-end standards.
JMO I think the K series are more likely to watch the market for so SE could work on other series as a final product. Yes, you might say then why would they release as an experiment-model to a market? Technology had always been moving faster and faster everyday. By putting products on the line to test the market would give the company a look in the market and to predict future needs. After that final products would show up in time to meet demands of the product.
Why do you think K700i doesn't have Memory Expansion in the first place? Pretty much is because SE needs to know at the time is it a need factor? That's why 42 Mb is put in to find out about this region. or even EDGE? may be because SE wants to know if operators supports it or not at the time release.
Posted: 2005-01-01 15:46:41
