Americas
Si, eso lei esta mańana. Toy de suerte!
Posted: 2010-09-22 18:00:51
mejorar la recepcion de gps, probado por mi y funciona:
To apply the work-around, follow these steps:
1. Navigate to Settings > Location & Security and uncheck the box next to "Use Wireless Networks".
2. Go to the phone's dialer and enter the number *#*#1472365#*#* then press send to access the phones LBSTestMode menu.
3. In the LBSTestMode menu, press “Application Settings” and change “Operation Mode” to “MS Based.”
4. Navigate to the “SUP/LCP Settings” and the SERVER & PORT to supl.google.com (make sure NOT to place “www.” in front) and port 7276.
5. Make sure the settings are saved and reboot your phone.
6. Navigate back to Settings > Location & Security and check the box next to “Use Wireless Networks.”
If you want to revert, simply follow the same instructions, replacing the settings in Step 4 with the original settings:
Operation Mode: Standalone
SERVER:
www.spirent-lcs.com (with the “www.” in front)
PORT: 7275
Posted: 2010-09-22 22:43:49
will try....
Posted: 2010-09-23 00:55:15
+2, pq hoy cogi lucha con el gps q me marcaba otra posicion.
Posted: 2010-09-23 15:46:59
Seńores Bajense Apktor del market... las repo las voy mandando por pm...
miles de app full...versiones pro.
nota: el proceso dura varios minutos actualizando la lista de app, dejenlo que termine y tomenlo con paciencia.
[ This Message was edited by: grafyman on 2010-09-23 22:48 ]
Posted: 2010-09-23 18:04:11
mandame lnk
Posted: 2010-09-23 18:28:34
gracias a apktor ya tengo logmein de nuevo....Rocks.
te mande un pm manin.
Posted: 2010-09-23 19:01:40
Logmein ta full full nitido manin!!!
Ya lo prob aqui.
Posted: 2010-09-24 10:41:03
Los q ven muchas peliculas de Fanatico o bajadas de torrentes, les recomiendo q se bajen estos videoplayers:
-Rockplayer - toca todos los formatos conocidos incl MKV y RMVB
-mVideoPlayer - toda divx y avi, mkv y hasta con subtitulos!!!
Busquenlo ya saben donde (apktor)
Posted: 2010-09-24 16:18:35
alguien se conoce alguna aplicacion que te permita conectar en android al skype? (en el market no aparece el skype de mi**da, y es para un amigo a lo legal)
Posted: 2010-09-24 23:13:27
