General discussions : Rumours : LowEnd-Walkman Codename Melinda
< Esato Forum Index > General discussions > Rumours > LowEnd-Walkman Codename Melinda Bookmark topic
Page <  12345678>
shaliron Posts: > 500
@PeterKay
I do think the design isn't too great, but most low end phones aren't very pretty anyway. It certainly looks better than the K310, so at least they are going forward.
@*Jojo*
Well the K310 looks very similar to the K700 anyway, so for a phone to be based on it, not much can really change.
And I think that this'll have memory expansion. 15MB is far too little, and adding a decent amount of flash memory is too expensive at this price level.
Posted: 2006-11-16 10:53:30
Sneff Posts: 4
Specs are the same like k320i - only the memory will be increased (12mb for a walkman would be ridiculous)
It will be released in Q1 07 together with roundabout a dozen other phones in different ranges
Announcement will be pretty soon
Unfortunately no walkman-button on the front, but on the left side will be a button
And if you don't like the front, you'll hate the back side:
camera looks like a bullet hole - no silver surroundings as we normally know it from SE
But I think the front looks pretty nice for a lowrange - the huge display glass which also covers the speakers has a nice look
[ This Message was edited by: Sneff on 2006-11-16 10:10 ]
Posted: 2006-11-16 11:07:12
goldenface Posts: > 500
Thanks for that info Sneff
I my W900i
[ This Message was edited by: goldenface on 2006-12-12 10:47 ]
Posted: 2006-11-16 11:09:06
@Sneff
Thanks for that info. Nice rendering though, I couldn't have done any better myself; it gives us a nice look into what it will finally look like.
So the memory will maybe be 128/256MB, no memory expansion then. OK for a low end then, as long as it is less than the W300.
Posted: 2006-11-16 11:32:18
Angello Posts: > 500
Sneff made a mistake. Melinda has a M2 slot and a 256mb card is added.
Posted: 2006-11-16 13:26:31
@beta-tester
That makes more sense. It is cheaper to do it that way rather than adding non-expandable flash memory to the phone. As I always suspected.
Posted: 2006-11-16 13:29:39
And the Walkman button is positioned on the left side of it like on the W900i. Remember?
Posted: 2006-11-16 13:31:58
@beta-tester
So that means that there isn't a play/pause button anymore? The W900 had one on its d-pad, but this one has a joystick.
Posted: 2006-11-16 13:34:23
UHH I don't know, because I never seen the proper firmware of this phone. The firmware I#ve seen is the one of the k310i
Posted: 2006-11-16 13:54:08
Hmyzak_SE Posts: 177
@beta-tester
And what about camera? Will it have megapixel camera or VGA (640x480)?
Posted: 2006-11-16 17:26:22
Page <  12345678>
