Sony Ericsson / Sony : Symbian phones : New Satio Firmware R1CA
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > New Satio Firmware R1CA Bookmark topic
Page <  123 ... 353637 ... 555657>
jmcomms Posts: > 500
Well, since my last post - the battery meter is still showing just under half (about the same as it was when I went to bed 6.5 hours ago). Okay, this is just one night - but the fact it is still switched on is a positive sign!
I am going to try the Picasa upload service shortly. I have to re-enter my details as I'd not used it since a previous hard reset. I would suggest that deleting the settings and re-entering them might be a good idea though.
Oh, and another big difference is that RoadSync has been updated and now works with Google contacts, calendar, tasks and email! Actually, that's a HUGE difference as it was totally useless before! I can now, hopefully, use my Satio for email after all - previously it was almost impossible with Google on account of it thinking a read message should be removed from the inbox (it seemed to assume read = deleted).
[ This Message was edited by: jmcomms on 2009-12-05 08:32 ]
Posted: 2009-12-05 09:22:37
Email synced, but so far no calendar or contacts. It might be a problem with Google, so I will wait before moaning.. even though RoadSync did delete all my contacts and calendar appointments so there's nothing on my phone now... grrr!
Posted: 2009-12-05 10:59:07
basithz Posts: 253
with the new firmware does the internet have kinetic scrolling
Posted: 2009-12-05 11:16:14
dipb Posts: 209
My picasaweb abd blogger clients stopped working after the firmware update.
Now when I touch them, it gives an error "cannot update web services"... strange !!!
It seems the "Go to web service" is gone now.
Does anyone have any clue on how to correct this ?
[ This Message was edited by: dipb on 2009-12-05 10:24 ]
Posted: 2009-12-05 11:17:38
herasymcuk Posts: 252
I have the same problem with PicasaWeb.
Posted: 2009-12-05 11:22:48
iqmaster158 Posts: 127
On 2009-12-05 06:42:56, redhunter wrote:
Updating mine, red, unbranded, 117.5MB :| maybe because it's including East Asian languages support
116.2mb mate and no such difficult language. i guess its beacause of vodafone branding.
Posted: 2009-12-05 11:30:15
TheHamster Posts: 50
PicasaWeb stopped working: Thanks for to all confirming my new bug. Oh well, Hopefully there's a workaround. I've just been looking at the picasa email updating. But hey this was working before the upgrade and it's splashed all over the adverts.
Posted: 2009-12-05 11:49:00
basithz Posts: 253
does the new firmware give the internet kinetic scrolling on the satio
Posted: 2009-12-05 14:04:48
mikely_28 Posts: 466
Does anyone have same problem as me? GPS receiver don't turn off automaticlly after using Sygic nav. I have to turn off the cell and turn it on. Than GPS receiver will turn off. With old FW there was not such problem. After one day SwissManager shows 48% battery level.
Posted: 2009-12-05 14:10:44
I set up Picasaweb and I can view existing photos in the media application (web albums), but trying to upload an image seems to do nothing (but I DO have the upload to web option).
RoadSync works fine for contacts and calendar appointments, but I've had to disable email because it is causing an error that stops the sync continuing. So, looks like I am still without email on the Satio and will have to always carry my BlackBerry with me instead.
And, no, there's no kinetic scrolling in the web browser or anything else that didn't have it before; but the web browser seems faster when using Wi-Fi - may even render pages slightly quicker.
To speed the phone up, I reckon there was something that caused problems in the background that has been fixed or removed. This may have also drained the battery. The keylock seems to work better now and even the screen rotation seems better (doesn't rotate just by tipping the phone a few degrees anymore - now it's when it tips around 45 degrees or more).
I have now had a freeze though; when I started the camera, it went blank with white boxes for where the on-screen icons would be. At this point, I had to remove the battery and restart.
Posted: 2009-12-05 14:34:49
