Sony Ericsson / Sony : UMTS / 3G : K600i / K608i / V600i Firmware details & bugs
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > K600i / K608i / V600i Firmware details & bugs Bookmark topic
Page <  123, 456 ... 212223>
sgcu Posts: 8
Jezza21:
I get the same thing if I try that way. says you have the latest installed.
btw, mine also has R2k005 installed
Posted: 2005-12-20 19:33:44
Jezza21 Posts: 20
Thanks sgcu. I guess we'll just have to wait for an update.............
Posted: 2005-12-21 11:30:29
kabukijep Posts: 185
your reckon this will work with a normal K600i as well?
On 2005-12-20 16:33:08, Jezza21 wrote:
I think you can use the USB cable, it's just not very clear how to do it. If you check out this link http://www.sonyericsson.com/s[....]s&lm=ps1_1&pid=10290&fid=21839 it talks about the USB flash drivers being installed by the program. What I found works for me is if while holding the c button and plugging in the USB cable I press the power button the SEUS seems to recognise the phone and check for updates. There doesn't seem to be one for the V600 though.
Posted: 2005-12-22 05:00:00
Jezza21 Posts: 20
kabukijep-Give it a go, I don't see why it shouldnt work. My understanding is that the K600 and V600 are basically the same phone but with different branding.
Posted: 2005-12-22 21:42:50
uukk Posts: 11
On 2005-12-20 19:33:44, sgcu wrote:
Jezza21:
No the last fw are:
R2T002
Ciao
Posted: 2005-12-23 08:51:52
Lunkan Posts: 22
I managed to update the flash drivers (but there were no yellow exclamation mark).
But when I start the program I just get the message saying that there is no flash stand connected.
When should I press the C-button and power button, have tried everything...
Posted: 2005-12-23 09:00:43
619 Posts: > 500
try to flash/upgrade your k6 using dss-25
Posted: 2005-12-23 10:45:46
Jezza21 Posts: 20
uukk-Is that firmware for the V600 or K600? Are you in the Uk or somewhere else? Also, did you get the firmware from the update service? Just curious........
Posted: 2005-12-23 11:34:00
619 Posts: > 500
hmm.. not sure, as i always davinciteam.com to upgrade my phones
Posted: 2005-12-23 11:42:03
uukk Posts: 11
My phone is K600i EU5.
No I upgraded by total*** and now SEUS report "you have the last firmware" before only "error, contact Service".
Ciao
Posted: 2005-12-23 12:25:55
