Sony Ericsson / Sony : Software, Firmware and Drivers : Withan™ Camera Driver V3/S3 Rev.1 for SE k790/k800/k810 phones
On 2008-02-01 20:09:37, mindshifter wrote:
Number1 2.96 and Ultimate v2.11 Withan color comparement:
docmode, macro, FL on, auto color balance
Number1: ExposureTime : 1/40Sec, ISOSpeedRatings : 100
Ultimate: ExposureTime : 1/200Sec, ISOSpeedRatings : 100
the problem is:
on Number1 - gray and silver colors have added red (should be like on Ultimate)
on Ultimate - white color has some blue (bottom right text "everglide" and BT grip handle (with PenDrive text) - should be like on Number1)
it's easy to fix if I add 25% red to photo (gray still stays gray and white becomes true white) but is it possible to adjust flash temperature or something to get correct colors?
Ultimate after adding 25% of red color (RGB: 234,26,26):
Can you shot the same pics using Fluorescent WB? thanks
[ This Message was edited by: jomateixa on 2008-02-01 20:07 ]
Posted: 2008-02-01 21:06:27
Vivid 2.11
Twilight landscape EV -0.7
Macro with flash EV-0.7 / auto
Withan 2.11
Macro flash on EV-0.7 / auto
[ This Message was edited by: showbiz on 2008-02-02 20:26 ]
Posted: 2008-02-01 21:07:46
sure:
daylight
cloudy
fluorescent
incandescent
I think daylight gives best results and fluorescent is second
edit:
on second thought fluorescent is better
K800i R8BA024
[ This Message was edited by: mindshifter on 2008-02-01 22:40 ]
Posted: 2008-02-01 23:30:02
ultimate vivid color v2.1
Posted: 2008-02-02 00:21:06
Thanks for the answer jomateixa
I've already read all posts, that's true, I should flash drivers with standard, and not with vivid
I can't add drivers from my computer, then I have to think about the best drivers
I've a question for you jomateixa, what is the best drivers for indoors pict ? Withan or Standard ? Thanks a lot again for your amazing job !
[ This Message was edited by: disizthesnak on 2008-02-02 15:48 ]
Posted: 2008-02-02 14:49:16
jomateixa what is the best drivers for daylight and indoors pictures ? 2.11 Withan or 2.11 Standard ? I don't need night mode pictures just i need the best driver for outside and inside. So Wihthan , Vivid or Standard? Please i want to know your opinion.
Posted: 2008-02-02 22:28:49
k 790 ULTİMATE VİVİD COLOUR V 2.1 ile çekildi [:'(]
[ This Message was edited by: farukkk on 2008-02-04 22:49 ]
Posted: 2008-02-03 03:41:37
mindshifter .. can you show me where you made the change in the code ? "Ultimate after adding 25% of red color (RGB: 234,26,26):" 19x
Posted: 2008-02-03 08:49:13
Posted: 2008-02-03 11:17:14
I didn't change camdriver. I used photoshop to add this color for whole picture
I think the best is to use auto WB and then correct it in photoshop or use fluorescent WB and correct it too
. In fluorescent WB less changes are needed.
Posted: 2008-02-03 14:12:55
