General discussions : Rumours : Sony Ericsson P3i coming
> Topic Locked
Esato Forum Index > General discussions > Rumours > Sony Ericsson P3i coming Bookmark topic
Page <  123 ... 567 ... 111213>
PeterKay Posts: > 500
On 2007-10-07 22:28:11, park wrote:
P3i
whats that under video????
can't make it out!
Posted: 2007-10-08 01:59:58
rss_ndrsn Posts: > 500
I hope P3i will have the following features:
3.0 inch 16 million colors VGA touch sensitive screen, 760 dpi
5.0 megapixel CCD sensor camera with 3x optical zoom, AF , Xenon flash and 6 Led lights
VGA@30fps; QVGA@120fps video recording
Walkman 3.0
3.5 mm jack
Superb quality stereo speaker/s
DVB-H/?
Qualcomm MSM7200 chipset @ 528 mhz
256 flash, 128/256 Ram memory
Memory card dual-slot - M2/MicroSD
Quad-band/GSM/EDGE/HSPDA/HSUPA
Bluetooth 2.1 with EDR
Wi-fi b/g
Mini-USB, Full Speed
Built-in GPS with A-GPS
1500mAh battery or higher capacity
Slim design
hhhhmm.
[ This Message was edited by: rss_ndrsn on 2007-10-08 08:22 ]
Posted: 2007-10-08 08:52:03
sealover94 Posts: > 500
well i think that SE is giving up.....
i heard about 2.6 inches screen....
All the mobile companies make larger screens and only SE.....make them smaller.....
It seems that the iphone didn't wake them up....
Damn you SE....
Make REAL phones with BIG touch screens!
Posted: 2007-10-08 09:28:44
chuksy Posts: 224
These are all rumours....lets wait till the real stuff is released-then we can throw all manner of accusations at them.
Posted: 2007-10-08 09:33:51
Damn you SE....
Maybe SE will suprise us. I heard there is a new brand to be introduced.
Posted: 2007-10-08 10:03:57
chombos1 Posts: > 500
do you realy expect P3i to have those capabilities !!!!!!! woww
and how many hours .... em .... minutes do you want to work with it.
do you know that a 24bit color screen needs much more power than a 262k one to light up even not taking into account the VGA resolution.
i think that the P3i will have a 2.8" VGA 262k color screen. you won't notice the color depth in that resolution. actually there is no visual difference between a 24bit and 18bit color on a 2.8" VGA screen. and the 18bit one is less power consuming.
760dpi? what's that?
the P990i screen is 2.8" QVGA it means that the dpi of the screen is about 114.3dpi and a VGA at the same size would be 228.6dpi not 760dpi!!
and about the camera: i think it will be 5MP AF with flash but not xenon or 3+ LEDs.
and VGA@15fps with QVGA@30fps will be more likely on P3i
i dont like to fill up my 4GB mem only with only 3 hours of video recording.
who hates VGA@30fs but it is unlikely to be on P3i (maybe on the next cybershot flagship)
and it must have Wi-Fi b/g must be quad band along with HSDPA.
Ram? should be the same size as the P1i
it shuold have daul mem support.
GPS and 3.5mm jack are good ideas.
[ This Message was edited by: chombos1 on 2007-10-08 10:52 ]
Posted: 2007-10-08 11:39:48
What a REAL p990 successor must have (don't forget..we are talking about q1,q2 of 2008) :
-At least the same camera as p1 with qvga - 30fps video rec
-The same internal memory as p1.
-VGA hand-touch screen AT LEAST 3 inches (iphone has 3,5 and nokia e90 4) the number of the colors is not a problem...(i prefer 256000 for energy economy)
-At least...and i mean AT LEAST....the 330 Mhz ARM processor
-GPS & wifi b/g & miniUSB & HSDPA, 3.6 Mbps
-radio,gprs,ir,bluetooth as p990
-stereo QUALITY loudspeakers
And a >1000mAh battery capacity ( e90 has 1500mAh !!!)
I prefer to have all these and remain the same size as p1.
Bring back the 5-way jog dial !!!
[ This Message was edited by: sealover94 on 2007-10-08 11:11 ]
Posted: 2007-10-08 12:08:40
agreed!
the battery capacity must be higher than ... say 1200mah
to support the screen and GPS (if there is to be) effectively.
forgot to metion the processor should be 333+ MHz
so it can handle for example normal WMV files while having some programs running in the background.
the 5-way jog dial is a good addition (return),
and i hope it will be smaller than the P990.
Posted: 2007-10-08 12:29:07
JuanPablo Posts: > 500
I doubt the screen will be THAT big. I bet it'll be 2.6 to 2.8 inches
Posted: 2007-10-08 16:43:10
Why is it soooooo difficult to make a larger screen?it is the future in mobiles....And iphone is only the beginning...
-Hand touchscreens need size!
-GPS needs large screens!
-vga resolution is useless in a 2,6 inches screen....too small to take advantage!
-mutlimedia features (video player..) need large screens!!
Posted: 2007-10-08 17:31:06
New Topic   Topic Locked
