Manufacturer Discussion : Nokia : Nokia Lumia 620 Thread And Discussion
< Esato Forum Index > Manufacturer Discussion > Nokia > Nokia Lumia 620 Thread And Discussion Bookmark topic
Page <  123 ... 567 ... 181920>
fluke9 Posts: 461
Thanks Sean
Think I may return to my roots.
Posted: 2013-03-02 00:39:25
Del Posts: > 500
Dam your 620 does look nice Sean, I do miss my old 820 sometimes
Posted: 2013-03-02 00:52:55
Bonovox Posts: > 500
You had an 820?? Wow i would have kept it. I may get the new 720 when it arrives. I am gonna stay with WP8 now i found my niche with Windows Phone. I got the yellow cover off eBay but they only had the white and magenta. Wanted the Cyan or lime green. You can almost taste these colours like Skittles Also video recording Nokia uses HAAC mics which are brilliant for loud concerts no distortion. Really love this little phone.
Material things don't matter,but Rock n Roll does!!!!
Nokia Lumia 620
AKA,Bonovox
[ This Message was edited by: Sean72 on 2013-03-02 00:31 ]
Posted: 2013-03-02 01:25:00
cu015170 Posts: > 500
Nokia Lumia 620
AKA,Bonovox
It wooks great with that cover.. the 720 has a better camera/battery so its probably a safe bet.
The HAAC mics are awesome.. shame WP doesn't support stereo recording, but maybe one day they can figure out how to enable it.
Posted: 2013-03-02 02:37:04
Yes the 720 has a first for a smartphone camera f1.9 aperture
Posted: 2013-03-02 03:07:00
jack00 Posts: > 500
just one thing
no one should buy the 620 (i did)
it has a unresolved multitouch issue
test your unit
http://www.youtube.com/watch?v=_8qL8uaTLac
Posted: 2013-03-02 17:23:17
On 2013-03-02 17:23:17, jack00 wrote:
just one thing
test your unit
Well,mine doesn't so it cannot be all devices. You cannot tell people not to buy something based on a number of phones with an issue. If mine doesn't then it's not all of them
Posted: 2013-03-02 19:27:09
Posted: 2013-03-02 19:33:17
Del Posts: > 500
Nokia Lumia 620
AKA,Bonovox
Yep I had an 820 for a while, don't get me wrong it's a great phone, loved the wireless charging but wp8 just couldn't do what I wanted it to do at that time, don't know what its like now with the portico update though, but the 820 is a great phone;)
I'm gonna hold off buying another phone till later in the year and you never know if wp8 has addressed the issues that I had with it then I will definitely consider another.
Posted: 2013-03-02 19:55:48
OK,what issues did you not like??
Posted: 2013-03-02 20:56:02
