General discussions : Rumours : Sony Xperia rumours 2022
< Esato Forum Index > General discussions > Rumours > Sony Xperia rumours 2022 Bookmark topic
Page <  123 ... 575859 ... 878889>
Archdragoon Posts: > 500
iPhone users : First time ?
Posted: 2022-05-01 10:39:26
Hawk12 Posts: > 500
New video: "it feels like you have a big optical lens in your hands".
Big lenses are : 200-600mm, 400mm, 600mm. 🤔
i would feel satisfied with a 70-200, but a fixed 70 + 200-600 would be beyond a dream.
[ This Message was edited by: Hawk12 on 2022-05-02 09:51 ]
Posted: 2022-05-02 10:37:44
goldenface Posts: > 500
https://youtu.be/vLWiXNvEVY0
For Content Creators.
Posted: 2022-05-02 11:05:06
Ppl Posts: > 500
3 buttons on the side again like the original 1
Is the fps under screen?
Edit:
That middle button doesn't look like an integrated fps one.
The silver frame was different.
[ This Message was edited by: Ppl on 2022-05-02 15:11 ]
Posted: 2022-05-02 13:33:51
Hawk12 Posts: > 500
Google button is gone
https://m.weibo.cn/detail/4762905100419755
In screen FPS makes screen brightness uneven there. It messes with uniformity.
I have a doubt. Why instead of using an exmor of size 1/1.X, not using a smaller but Starvis one? They have much more light sensitivity and DR than ones with conventional photo diodes.
[ This Message was edited by: Hawk12 on 2022-05-02 14:13 ]
Posted: 2022-05-02 13:38:36
tai020381 Posts: > 500
I thinks its 10 times optical zoom so likely 240mm lens as rumoured previously the same number of zoom as the Galaxy S22 .
Posted: 2022-05-02 15:44:27
cool_sauce Posts: 376
Thats the original 1 thats why it shows three buttons. I guess Sony has finally made a differentiation between 1 and PRO-I lines and as we suspected 1 is going to be about zoom.
Posted: 2022-05-02 19:47:18
herasymcuk Posts: 251
[ This Message was edited by: herasymcuk on 2022-05-02 19:01 ]
Posted: 2022-05-02 19:58:47
RacSony Posts: > 500
according to this article, docomo's ALL new models are 5G phones including the entry model xperia ace 3.
https://sumahodigest.com/?p=9621
I remember someone said one of new xperias which is most likely ace 3 will have 4g helio chipset.
Posted: 2022-05-02 22:16:46
Hawk12 Posts: > 500
Maybe ace3 is the one with 695. Then 10iv got pushed to 778.
Posted: 2022-05-02 23:20:20
