Sony Ericsson / Sony : Tips and tricks : Handler Mods Download Page
< Esato Forum Index > Sony Ericsson / Sony > Tips and tricks > Handler Mods Download Page Bookmark topic
Page <  123 ... 8910 ... 161718>
Cyborg_a0 Posts: 283
The cgi is down, that's why.
Posted: 2009-12-27 16:00:00
@anningg
how about in vodacom
using vlive setting
bolt or ucweb setting
front query:
live.vodafone.com@
or
front query:
live.vodafone.com.t9space.com/power/s/http/
i prefer to use @3k it's much faster
[ This Message was edited by: Cyborg_a0 on 2009-12-27 15:25 ]
Posted: 2009-12-27 16:14:00
Excalibur69 Posts: > 500
@kylie, please let us know the full trick you've entered, please post it so as to let us know if it's really the real mckoy. Ucweb and bolt tricks are quite different from OM trick for it doesn't need http server anymore, only front query. If the trick i posted doesn't work, you may try, venus, flyproxy and concealme in cgi syntax.
Posted: 2009-12-27 16:18:07
anningg Posts: 78
i tried the @trick and it ddnt work
Posted: 2009-12-27 18:38:00
kylie-g Posts: 7
Ok... I tried a few cgi tricks e.g [freesite].t9space.com/power/s/http/ and [freesite].gowingo.com/cgi-bin/nph-get.cgi/000000a/http/.... I also tried the @3k, dot3k as wel as tha ip3k e.g flyproxy and the one u gave me...
Posted: 2009-12-27 20:47:28
Ok, one more thing brother, when you use the gowingo cgi, have you changed your ip to gowingo.com or its numeric value at port 80? If so, then enter once again the trick and remove the url gowingo.com from the syntax and it will look like this:
[freesite]/cgi-bin/nph-get.cgi/000000A/http/
if it doesn't worked, then try again another cgi.
GOOD LUCK!
Posted: 2009-12-28 00:30:02
@kylie-g, here's some:
proxy: flyproxy.com or 208.85.242.221 at port 80
front query: freesite/nph-proxy.pl/010110A/http/
proxy: 195.205.100.200 at port 80
front query: freesite/~mbar3/net/nph-proxy.cgi/010110A/http/
Posted: 2009-12-28 01:41:28
kylie-g Posts: 7
Hey man. Tried all of that. Nothing works. Gives me a connection error
Posted: 2009-12-28 03:08:56
Bro, have you ever tried to use a cgi on your OM? If you made it run on your OM then it'll work on any apps requiring front query only.
[ This Message was edited by: Excalibur69 on 2009-12-28 06:29 ]
Posted: 2009-12-28 07:24:49
kylie-g Posts: 7
I have tried it man. But you said the way om and ucweb and bolt connect is difrnt. We need to make contact with antofungky to find out...
Posted: 2009-12-28 08:29:26
