General discussions : Rumours : P700 is on its way
> Topic Locked
Esato Forum Index > General discussions > Rumours > P700 is on its way Bookmark topic
Page <  123 ... 838485 ... 128129130>
darkman Posts: 138
Fantastic phone:D
Posted: 2007-04-22 16:14:22
Caspa Posts: > 500
The RAM test on the P700 should give us info on what we can expect from the current crop of UIQ3 devices. If leaks exist the implications are massive.
The P700 wont have a problem as Adhnk said.
Posted: 2007-04-22 16:16:00
borizz Posts: 32
well I know that the apps on the video are started. but also the switching is much faster. and I'm really curious if the CPU is the same and if all that speed is only based on RAM.
Posted: 2007-04-22 16:17:48
tinaxdgreat Posts: 22
Can it run skype? can it play videos from youtube directly without downloading the video? One guy mentioned that the price would be around $700.00 which is almost the same price as pocket pcs. IMO wIthout these features i mentioned above then this is too expensive for a phone with less features than pocket pcs.
Posted: 2007-04-22 16:30:54
deuxani Posts: > 500
Btw... is it just me who thinks that a stylus on the left side is a bad solution? SE want you to hold the device in your left hand and use the stylus with your right, so why do they put the stylus on the left top part which is the most unconvenient location to put it.
Posted: 2007-04-22 16:44:18
PeterKay Posts: > 500
I thought it was a bad idea at first, but now getting use to it.
Posted: 2007-04-22 16:45:55
masseur Posts: > 500
I'm used to that since having the M600 for a long time. what was unusual to me was on the k-jam and TyTN with the stylus coming out of the bottom of the right hand side!
Posted: 2007-04-22 16:51:23
dr_thug Posts: > 500
On 2007-04-22 15:59:39, ares wrote:
Truth is, most people dont need 20 apps running at same time, althogh is nice to have the option. I guess if the upgrade to symbian 9.3 puts the p990 with more than 20mb at boot, and no memory leaks, we will be more than ok untill the true successor comes
As ares said,most users don't open 20 applications at a time.Most open 5-10 applications.I use media player,opera,agile,calender,contacts and couple of other apps running at a time.If SE can provide that with no more auto shutdowns,most will be happy.I must also add that the last firmware is very stable and improved the multitasking.And trusting ares,when P7 is launched,the firmware found in it will be available in P990.
So other than this,differences i found are...
+ points :Better cam,More RAM,Better battery
- points :No flip,Smaller screen,Half qwerty
Not worth an upgrade for P990 users IMO.
Posted: 2007-04-22 16:55:16
Yeah, it seems unusual but it actually is the best place for righthanded people I would say.
But you both say you can get used to it very quickly, so no hassel.
Posted: 2007-04-22 16:55:30
Mizzle Posts: > 500
The stylus seems bigger compared to M600, P990 and W950 IMO. can anybody confirm?
Posted: 2007-04-22 17:11:14
New Topic   Topic Locked
