Sony Ericsson / Sony : Accessories : Memory Stick FAQ
< Esato Forum Index > Sony Ericsson / Sony > Accessories > Memory Stick FAQ Bookmark topic
Page <  123, ... 212223>
bobsprout Posts: 56
"u gt any help on the memory stick adapters as i do not know where to place the adapter in my k750i! any suggestions?"
hahahaha, wedge it as hard as you can in the memory card slot.
or just realise that the adaptor goes into a card reader for pc use
Posted: 2005-12-21 18:46:41
baste07 Posts: > 500
how does the psp branded ms duo pro compare with the oter models/brands? is it just like the regular sony ms duo pro?
Posted: 2006-01-10 15:01:24
whizkidd Posts: > 500
Quote: On 2006-01-10 15:01:24, baste07 wrote: how does the psp branded ms duo pro compare with the oter models/brands? is it just like the regular sony ms duo pro? I guess the psp branded duos are no different from the ones used on other platforms.
Posted: 2006-01-11 04:04:00
are they the same with highspeed pro duos? or just the regular ones?
Posted: 2006-01-12 14:59:40
mrao Posts: > 500
methinks they're different...
Posted: 2006-02-11 13:14:50
*Jojo* Posts: > 500
@whiz - Nice matey! I have a 'Q' though . . . I am planning to get me a 64 MB Sony Memory Stick Duo for my 'old' P800 . . . the guy is offering me the 'stock' 64 MB inserted on his K750i, will this work on my P800 then
As you have stated:
_______________________________________________
Q2. What types of Memory Stick media are currently available?
A:The current types of Memory sticks are:
Memory Stick
Memory Stick Duo (Used in P800, P900 and S700.)
Memory Stick Pro
Memory Stick Duo Pro or Pro Duo.(Used in newer phones like P910, K750 ,W800 and so on..)
________________________________________________
Thanks!
Posted: 2006-02-11 17:47:09
jojo, the stock memory stick on the K750 wont work on the P8 coz its a memory stick "PRO" duo while the P800 uses the normal memory sticks.
The Memory Stck Duos.
Posted: 2006-02-11 18:20:43
*Jojo* Posts: > 500
@whiz - Are you sure mate? As I am going to meet the seller 7 hours from now . . .
Posted: 2006-02-11 18:28:37
masseur Posts: > 500
the 64mb memory stick that comes with the K750 is not a PRO and so it is compatible with the P800
Posted: 2006-02-11 18:47:29
*Jojo* Posts: > 500
@masseur - Wheeeeeeeew Now what is what here . . . the Mods word against the Author of the thread I will be meeting the seller in 7 hours time . . . make up your minds mates I really wanted this one! Thanks!
Posted: 2006-02-11 18:50:56
