Tips and tricks
> Sony Ericsson Codes
Turning on phone without sim is not working.
Posted: 2009-04-17 09:02:00
I have a w880i that is asking for a 'phone lock code'.
I have tried xs++ and also setool and these do not detect my phone, my pc comes up with a message 'USB device not recognised'.
Is there any way to reset or find out the 'Phone lock code' directly from the keypad of the phone or from any of the secret menu's?
Posted: 2009-04-17 14:58:26
I had the same problem yesterday. I updated the phone with SEUS and then used the code 1234, and it worked. I did not try the code before updating though, so it may work without an update.
Posted: 2009-05-07 01:32:25
On 2007-06-18 15:43:25, axxxr wrote:
Having problems figuring out how to do stuff on your
phone? well this may help!
Opening phone without a SIM card: **04*0000*0000*0000# followed by on Wrong Pin number
its not the code for work phone without sim
but its for using any phone without knowing the phone code
Posted: 2009-09-30 12:53:47
Opening phone without a SIM card: **04*0000*0000*0000# followed by on ‘Wrong Pin’ number
No, I try this code, but phone again will phone lock code.
Posted: 2009-09-30 19:02:24
Guys there is this code < * * < i.e left. star. star. left I found networks. So I tried changing things you know modify. Now just left with 1 attempt all. what will happen if this last 1 block? help guys or please tell me the network code. thanks
Posted: 2009-10-03 09:25:00
try this ←8888→ it will change language to set as on sim.
Note: set language to other language, and try that, you will see.
And **04*0000*0000*0000# that code used to chang PIN CODE bassed on sim card.
**04*oldpin*newpin*newpin#
"←" mean d-pad or joypad left, "→" mean d-pad or joypad right
[ This Message was edited by: Syahroni on 2014-03-23 05:09 ]
Posted: 2014-03-23 05:49:00
