Sony Ericsson / Sony : Software, Firmware and Drivers : navar k850 v9.2 x3 FINAL camdrive
< Esato Forum Index > Sony Ericsson / Sony > Software, Firmware and Drivers > navar k850 v9.2 x3 FINAL camdrive Bookmark topic
Page <  123 ... 50, 515253>
Navar Posts: > 500
Up
Posted: 2010-11-24 09:25:44
D1ma Posts: 54
Evrybody try this driver http://www.4shared.com/file/DSqxSRf2/camdriver0.html
It's the best in auto shouting!... Give mach more detail and more accurate focus
Posted: 2010-11-26 13:13:01
Uzebnet Posts: 1
Assalamu alekum, special gratitude Navar from Uzbekistan. Tell to me, than differ the driver with manual setting and without manual? In advance thanks.
Posted: 2010-12-11 02:41:49
amnher Posts: > 500
Finally found a very good autodriver. Just wanna ask... Im using without manual setting. Is the settings the same with label of original en.lng?
Posted: 2010-12-30 11:25:00
Navar Posts: > 500
iam glad to hear that ya with the orginal en.lng that you must use it with the camdrive that dont have manual settings but if you want to use the copy of the camdrive with manual settings you must put the en.lng file that inside your phone. you will find it in the camdrive folder
Posted: 2011-01-02 07:27:07
amnher Posts: > 500
Its nice. It has slow flash sync in twilight. Though sometimes daylight shots seems blur i'll provide screenshots on it. By the way is it ok if you provide info about the following:
1. auto
2. auto + RER
3. Twilight Landscape
4. Twilight Portrait
5. Twilight Portrait + RER
I mean their differences from stock driver
[ This Message was edited by: amnher on 2011-01-02 13:26 ]
Posted: 2011-01-02 13:51:48
amnher Posts: > 500
Another thing Navar the twilight portrait is a bit yellowish or less color. What do you think ? Ill post pictures. it's my girl by the way
[ This Message was edited by: amnher on 2011-02-02 11:51 ]
Posted: 2011-02-02 12:47:50
Navar Posts: > 500
Up.i hope it will help
Posted: 2011-06-08 13:50:38
amnher Posts: > 500
can you fix the less saturation problem on some shots on twilight portrait shots?
Posted: 2011-06-09 02:56:17
zagi988 Posts: 39
@navar: I need a medium size favor...could you edit ur non-manual driver and add only MANUAL FOCUS and AF EXPOSURE LOCK, one under another in ISO menu? And also a bit stronger contrast, cuz I always need to add +15 or +20 in xnView to get a better picture. I'm asking u this cuz my camera key is dead, so I'm using ur manual driver 4 focus and expo lock but I don't need other manual functions. I would be maximum gratefull.
[ This Message was edited by: zagi988 on 2011-06-11 22:15 ]
Posted: 2011-06-11 21:01:17
