Sony Ericsson / Sony : Symbian phones : camdriver for satio (almost released) by eltoffer
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > camdriver for satio (almost released) by eltoffer Bookmark topic
Page <  123 ... 11, 121314>
norbi_nw Posts: > 500
then i really dont know how to apply it :/ ... can you make a step by step walkthrough?
ex. restore original camera, restart phone, start open4all, leave c2z open for x day, etc.
i really dont get it how to do it.
I dont have the 10282EDC.cre not even in Z...
Posted: 2010-07-07 09:12:24
Zacie Posts: 33
@eltoffer: I read the question you wrote on Raafat blog and and I say that you can only try to decompile it. Also you can using a hex editor to mod.
@norbi_nw: 10282EDC.txt is not really used, so 10282EDC.cre has no importance.
[ This Message was edited by: Zacie on 2010-07-07 12:39 ]
Posted: 2010-07-07 13:39:19
so only the 6989.txt is important... still i dont know how to get it working as i deleted the CRE and replaced it with TXT, restarted phone, opened C2Z, then started camera app... and still no change in bitrate.
Posted: 2010-07-07 13:45:24
Zacie Posts: 33
Yes, but remember you don't must replace the .txt file in the persists folder. Erase .cre and replace .txt in main 10202BE9 folder!
But... I make some tests and don't ever see any improvement.
So, good luck.
[ This Message was edited by: Zacie on 2010-07-07 13:24 ]
Posted: 2010-07-07 14:24:20
so you tested it too and video recording bitrate is the same? (look in file manager, video options and there find bitrate).
Posted: 2010-07-07 15:57:12
Lavdo Posts: 13
Really, I don't see any difference at all with this change. All the same, all the same.
Posted: 2010-07-08 13:32:24
riksilvers Posts: 139
so is the Satio camdriver firmware driven which is why it's impossible to mod?
Posted: 2010-07-11 15:18:19
bhooooooookk Posts: 56
the camera driver used in satio and 5800 is almost the same.
Posted: 2010-07-13 07:14:15
I have found you can manually fix the focus when recording video.
If while in photo mode you press the capture button halfway to set the focus and keep your finger there, then with another finger switch to video mode - you have set the focus for video recording.
Why it doesn't just do this automatically in video mode I will never know
[ This Message was edited by: riksilvers on 2010-07-16 14:20 ]
Posted: 2010-07-16 14:18:27
idumbakumar Posts: > 500
hey thats good find. i dont know this before... i was waiting for focus in video mode...
big big thanks............
Posted: 2010-07-16 16:21:03
