Sony Ericsson / Sony : Symbian phones : camdriver for satio (almost released) by eltoffer
< Esato Forum Index > Sony Ericsson / Sony > Symbian phones > camdriver for satio (almost released) by eltoffer Bookmark topic
Page <  123, 4 ... 121314>
daviep Posts: > 500
how do you replace the old cam drive,where does it go?
Posted: 2010-04-30 06:35:13
eltoffer Posts: 348
Instructions are located inside the rar file
camera modd by eltoffer
You must have a hacked phone
1.-enable open4all
2.-delete from c\\private\\10202be9\\persists
a)10282EDC.cre
b)10208696.cre
3.-copy files into path
4.-enable c2z patch
5.-restart ann enjoy
[ This Message was edited by: eltoffer on 2010-04-30 06:54 ]
Posted: 2010-04-30 06:37:48
Christoforo Posts: 64
what if we dont have the 2 files we are supposed to delete. i just copied the file that is it.
Posted: 2010-04-30 06:39:42
eltoffer Posts: 348
just delete the the files you find, no matter if its only one, at least is one
Posted: 2010-04-30 06:45:58
but i did not find 10282EDC.cre or 10208696.cre so i just copied your files anyways
Posted: 2010-04-30 07:04:56
eltoffer Posts: 348
BIG mistake sory sorry the correct path is
2.-delete from c\\\\private\\\\10202be9\\\\persists
do it ALL AGAIN, to make it works properly
Posted: 2010-04-30 07:53:58
cenzooooo89 Posts: 3
Just tested again on both a satio with original untouched firmware and this mod with same apps and files installed, things Ive noticed:
-Colour reproduction is much more accurate in both camera and video with the new mod
-camera images are roughly the same file size, if anything around 50kb higher with new mod
-video frame rate for WVA stands at a solid 23.65, and for VGA 29.59 for the new mod (.20fps higher for both VGA and WVGA compared to the unmodded firmware)
-edges of objects eg flower, leaf, book etc seem slightly more saturated in the modded files (have lost a tad of sharpness)
-noise in night shots drastically improved in the modded files
-JPEG compression however still quite strong
Posted: 2010-04-30 09:06:42
digitall1982 Posts: 6
hi everyone!
does it work without c2z patch?
i've got hacked phone but got no c2z installed
Posted: 2010-04-30 10:40:06
Luhccas-U1a Posts: > 500
Why don't you install C2z maker?
Is so easy do this... Better than get a problematic cellphone.
Look into Raafat's blog,there have a "how to"...
Posted: 2010-04-30 10:59:30
solante Posts: 12
Do you mean a noise reduction in night shots with the modded files?
Posted: 2010-04-30 11:57:24
