Sony Ericsson / Sony : Technical : T68 backgrounds via DRS-11
< Esato Forum Index > Sony Ericsson / Sony > Technical > T68 backgrounds via DRS-11 Bookmark topic
arnoldc Posts: > 500
@cruiser91,
According to Daniel Hertrich, the DRS-10 does not have a DCD (data carrier detect) line. The DRS-11 includes this, aside from using a newer chipset, MAX3386.
[ This Message was edited by: arnoldc on 2002-02-26 08:06 ]
Posted: 2002-02-25 04:02:00
Jowi Posts: > 500
On 2002-02-25 04:02, arnoldc wrote:
According to Daniel Hertrich, the DRS-10 does not have a DCD (data carried detect) line. The DRS-11 includes this, aside from using a newer chipset, MAX3386.
so bro, please explain, in layman's term, what is a DCD(data carried detect)?
Posted: 2002-02-25 16:36:00
DCD, together with DTR (data terminal ready), DSR (data set ready), RTS (request to send) and CTS (clear to send) are handshaking lines. These are used by devices to exchange information about their status (whether or not a device is ready, can send data, can receive data, etc). The need and use depends on the kind of data transmission you run and on the software which handles the transmission. I am not sure if this is good enough.
Know more about RS-232 interface by doing a search on the web.
Posted: 2002-02-26 12:42:00
ferrarista44 Posts: > 500
just a tip.
when using the MyPictures application with a data cable, it is better to "send file to phone" than just simply uploading a picture into a portfolio... the quality reduces if you upload pics from a portfolio rather than sending it directly...
i hope my observation is correct.
Posted: 2002-02-26 12:51:00
nelsongs Posts: 31
our T68 phones has a 256-color only. that's why, if you would notice, high resolution pics loaded on the phone wouldn't be of that good quality compared to the resolution seen on the PC.
Posted: 2002-02-26 13:51:00
