Sony Ericsson / Sony : Accessories : Smart Wireless Headset pro (replacement for MW600)
< Esato Forum Index > Sony Ericsson / Sony > Accessories > Smart Wireless Headset pro (replacement for MW600) Bookmark topic
Page <  1234567>
ofiaich Posts: > 500
thanks hihihans!
KetchupMania look good! My friends will laugh if they know I am listening!
Japanese does not display correctly on the Sony Smart Wireless Headset pro from the box.
Some Japanese display but some Kanji are replaced by a box -- [] so I have copied the font.bin to the root directory of the SD Card. Now charging it up and will read thoroughly and test all later!
Ofiaich
Posted: 2012-10-09 17:33:03
Hi everyone!
Now all working fine with font.bin in the root directory of the SD Card!
I have a new question!
Is there any reason why the Xperia Tablert S and Sony Smart Wireless Headset pro should not pair and work together?
Can't seem to get my tablet to see the headset and wonder what the problem is.
I have paired my headset with my Xperia T with no issues.
Any advice welcomed!
Ofiaich
Posted: 2012-10-10 02:08:01
Supa_Fly Posts: > 500
I think there is a menu function to allow more than 1 device pairing; lists paired devices separately on the display. I could be wrong but a pic of the display seemed to suggest that. Glad you got the font to display!!
Posted: 2012-10-10 02:45:55
thanks Hardened!
I remembered Multipoint functionality but forgot to look for it in the menu!
Thanks! Shopping to do, then will try again!
Ofiaich
Posted: 2012-10-10 10:07:52
all working now...
One more question about the Sony apps and Xperia Tablet S...
On my Xperia T... I can get these menus.. if I pull down the notifications bar that show the headset connected,
+++.... headset can be seen top left corner..
So I can choose what notifications I want to go to the headset... text, calendar, email etc.
I have downloaded all apps to the Sony Xperia Tablet S but I do not see the same way to choose notifications..
I guess either it is not there, or I am missing something obvious1
Ofiaich
[ This Message was edited by: ofiaich on 2012-10-11 12:23 ]
Posted: 2012-10-11 02:43:02
pt020 Posts: > 500
I have a battery problem with this headset ... it discharges also when it is turned off..
Posted: 2012-10-15 10:54:42
hydrodiver Posts: 6
Does anyone know how much compatibility these headphones get with an iPhone? The MW600 is completely compatible and I really like using them but I'm on my third pair as a result of the flimsy clip breaking every six months or so. I'm just concerned with being able to answer calls and being able to control music. I would appreciate any feedback from experienced users.
Thanks.
Posted: 2012-10-18 05:06:00
tobias84 Posts: 310
On 2012-10-11 02:43:02, ofiaich wrote:
all working now...
Ofiaich
Sorry for off-topic but, how do you get battery percentege in the status bar?
Posted: 2012-10-18 09:37:06
pt020 Posts: > 500
It has to do with the battery widgets settings
it is this widget
https://play.google.com/store[....]FuZHJvaWQucmVib3JuLmJldGEiXQ..
and it looks on my phone like this
But there are different widgets with different designs
[ This Message was edited by: pt020 on 2012-10-18 17:27 ]
Posted: 2012-10-18 16:54:29
Hi tobias84
It must be part of the James Bond theme on my Xperia T as it's always been there!
Ofiaich
Posted: 2012-10-18 17:10:42
Page <  1234567>
