General discussions : Esato forum : Esato is up again. But there are some issues.
General discussions >
Esato forum
You should now be able to upload photos taken with any type of mobile phone. We had some issue with the upload feature resulting that photos captured with a short list of handsets was impossible to save to the server.
Please try again now and report back if you still are having upload-problems.
Posted: 2017-01-15 22:36:01
Great. Thanks.
Posted: 2017-01-16 00:26:41
Can't set the phone model in profile settings
The list is probably to be returned by
https://members.esato.com/ajax_rankmodels.php , but it responds with 404.
[ This Message was edited by: bodqhrohro on 2018-12-03 11:24 ]
Posted: 2018-12-03 12:24:09
And I can't even create a post
It returns 500. The request:
curl 'https://www.esato.com/board/newtopic.php' --2.0 -H 'Host:
www.esato.com' -H 'User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:52.0) Gecko/20100101 Firefox/52.0 SeaMonkey/2.49.4' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8' -H 'Accept-Language: en-US,en;q=0.5' --compressed -H 'Referer:
https://www.esato.com/board/newtopic.php?forum=36' -H 'Cookie: LastVisit=1543844089; _ga=<REDACTED>; _gid=<REDACTED>; LastVisitTemp=1543588520; phpBBsession=<REDACTED>' -H 'Connection: keep-alive' -H 'Upgrade-Insecure-Requests: 1' -H 'Cache-Control: max-age=0' --data 'subject=Did+you+experience+overheating+because+of+UMTS%3F&message=---+tl%3Bdr+story+---%3Cbr+%2F%3E%0D%0A%3Cbr+%2F%3E%0D%0AI+had+never+expected+that+my+phone+would+wait+alive+for+the+launch+of+UMTS+by+major+operators+in+Ukraine%2C+but+it+finally+did%3A+in+2015+I+have+tried+it+a+lot+in+a+city%2C+and+in+2016+UMTS+have+even+reached+my+hometown.%3Cbr+%2F%3E%0D%0A%3Cbr+%2F%3E%0D%0AMy+model%2C+W660i%2C+has+no+EDGE+capability%2C+only+plain+GPRS+%28up+to+64+kbps%29+and+UMTS.+This+was+especially+painful+in+the+country+where+major+operators+had+no+licenses+for+UMTS+and+thus+put+their+efforts+in+providing+as+best+EDGE+as+possible.+And+it+has+no+Wi-Fi+capability%2C+so+until+the+launch+UMTS+I+had+no+ways+for+listening+to+streams+in+acceptable+quality+on+the+phone.%3Cbr+%2F%3E%0D%0A%3Cbr+%2F%3E%0D%0ASo%2C+up+to+September%2C+I+did+set+up+the+following+configuration+to+stream+music+on+the+phone%3A+mpd+server+on+my+notebook+with+HTTP+streaming+enabled%2C+ngrok+to+bypass+the+NAT+cage%2C+and+MFRadio+on+the+phone+to+play+the+stream.+That+way+I+could+listen+to+the+large+collection+when+working+in+the+yard.%3Cbr+%2F%3E%0D%0A%3Cbr+%2F%3E%0D%0A---+tl%3Bdr+end+---%3Cbr+%2F%3E%0D%0A%3Cbr+%2F%3E%0D%0AUnfortunately%2C+this+configuration+works+not+for+a+long+time.+The+most+significant+issue+is+fast+battery+drain+with%3A%3Cbr+%2F%3E%0D%0A%5Blist%5D%0D%0A%5B*%5D+active+3G+data+transfer%3B%3Cbr+%2F%3E%0D%0A%5B*%5D+speaker+working+at+maximum+loudness%3B%3Cbr+%2F%3E%0D%0A%5B*%5D+Java+app+running%3B%0D%0A%5B%2Flist%5D%3Cbr+%2F%3E%0D%0Asimultaneously.+And+this+was+a+fresh+battery%2C+I+replace+them+every+2+years+at+summer.+But+it+could+last+only+for+1%E2%80%932+hours+that+way.%3Cbr+%2F%3E%0D%0ABut+what+is+the+most+horrible%2C+is+that+after+about+20+minutes+of+such+hardworking%2C+the+phone+heats+a+lot%2C+even+if+placed+in+a+shadow.+Overheating+leads+to+the+failure+of+reading+of+internal+memory%3A+the+phone+becomes+almost+inoperable+in+such+condition%2C+and+requires+a+reboot.%3Cbr+%2F%3E%0D%0AI+tried+this+mockery+several+times%2C+then+stopped+tempting+the+fate%2C+as+avoiding+a+damage+to+electronics+and+a+battery+explosion+was+a+big+luck+already.+The+only+visible+result+of+that+was+an+early+manifestation+of+impedance+%28that%27s+when+the+reported+battery+level+is+less+than+it+actually+is+under+load%29%3A+usually+it+becomes+noticeable+only+after+a+year+of+battery+exploitation.%3Cbr+%2F%3E%0D%0ASo%2C+I%27m+not+sure%2C+what+is+the+reason+of+that.+Was+the+3G+module+itself+causing+the+overheat%3F+2.1+GHz+is+near+to+the+frequency+that+microwave+ovens+operate+on%2C+and+all+of+my+3G+modems+often+overheat+too%2C+but+without+any+damage+to+themselves.+Or+the+fast+battery+drain%3F+Or+both%3F¬ify=on&forum=36&submit=Post'
Sorry if you have spoilers support on the forum and I didn't notice that
[ This Message was edited by: bodqhrohro on 2018-12-03 12:48 ]
Posted: 2018-12-03 13:45:48
Again there is a problem with uploading images to the Photos section.
I get the error message that the uploaded image is larger than 20MB, even though it is less than 5MB.
Posted: 2021-08-10 21:45:54
Hi there.
Try posting it
here where laffen posted the news the site was up again.
Posted: 2021-08-10 22:20:08
On 2021-08-10 22:20:08, tranced wrote:
Hi there.
Try posting it
I just tried to post it there, but I got another error message:
"You do not have access to post to this forum."
So, can't upload photos, can't post to that forum, who knows what other issues there are that we don't know about
Posted: 2021-08-11 11:52:07
@ardzuna: my bad. I forgot that little detail.
@laffen: take a look here.
Posted: 2021-08-14 15:18:29
I notice that it is still impossible to upload a photo
Posted: 2021-09-19 09:35:52
Me too... for the last few weeks/month I get the upload button, select my photo and click upload. The photo never uploads, I just get a blank screen. I am currently using Chrome but have also tried via Edge.
Posted: 2021-12-13 13:03:21
