Sony Ericsson / Sony : Android : Sony Xperia 1 VI
< Esato Forum Index > Sony Ericsson / Sony > Android > Sony Xperia 1 VI Bookmark topic
Page <  123>
Hawk12 Posts: > 500
On 2024-05-26 05:18:11, tai020381 wrote:
On 2024-05-25 22:08:59, Hawk12 wrote:
I have not seen any statement from sony if this phone is compatible with the vlog kit.
Olle Nilsson was using it to shoot birds:
https://www.youtube.com/watch?v=OvNqBZwnM1E&t=3s
that was just tripod. Not that screen connected to phone to use rear cam as selfie. For example mark 3 cannot use it, just pro-i/mark4/mark5
Posted: 2024-05-26 16:10:16
profyler Posts: 105
Meh..
https://www.gsmarena.com/sony_xperia_1_vi-review-2699.php
Posted: 2024-05-27 09:46:27
tai020381 Posts: > 500
VS Galaxy S24 Ultra.
https://www.youtube.com/watch?v=cOavGHh1zkk
Posted: 2024-05-28 13:07:23
Theres still a slight chance of coming back to U.S :
https://androidsp.com/xperia-[....]asses-bluetooth-certification/
Posted: 2024-05-29 15:57:56
M-Ali Posts: 101
I think this was cancelled cause xperiaus pages were active till end of march so probably a last minute decision to pull out of US market
Posted: 2024-05-29 17:20:34
Here you go. This guy is using vlogging kit.
https://youtu.be/7W2okoilEUs?si=ijqeq-wT7Z_RSJ5x
Same from whatgear:
https://youtu.be/xaC9STcMS9Y?si=DSTyVfifszF6W02t
[ This Message was edited by: tai020381 on 2024-05-30 16:19 ]
Posted: 2024-05-30 14:59:29
MRVX Posts: 2
im in delema.. to choose which one.. xperia 1 vi or galaxy s24 ultra.. RM6+++ in malaysia
Posted: 2024-06-12 00:31:50
S24 ultra for countries out of US will likely use exynos chip. A factor for your consideration. Overall is your call though.
Posted: 2024-06-12 03:42:36
Sony considering making more scarlet color and also other colors!!
https://sumahodigest.com/?p=31027
Posted: 2024-06-13 23:42:51
cool_sauce Posts: 345
Had a chance to use 1VI for about four days, it was a loaner from my friend. I didn't use it as a cellphone but rather as a camera.
- Video recording is utter garbage, how in the hell you go from methodical Video Pro and Cinema Pro to something so this really? Can't adjust the gain, doesn't have 25fps, no audio input adjustment. no level indicator It's just horrible. But not as horrible as new app UI
- Video tab UI is the worst I've ever seen. Most of the UI elements are inside my viewfinder. What the hell is up with a black header that has useless options such as torch and "quick" swap of resolution and fps? Also torch is again present when you tap the settings icon.
- When you want to adjust the temperature and brightness you have to tap on the screen that was like the most unintuitive feature of old Xperia camera app back in the day of XZ, no one knew it existed unless they tapped on the screen by accident. The worst part is when you tap on the screen you lock subject tracking so once you are done with temp/exposure sliders you have to tap tracking rectangle to disable it.
- There are no focus and AE lock button in Photo Pro tab, you have to half press the shutter button to engage it. Also when you do half a press some icons on screen dim more than others. That tells you they didn't pay attention to UI at all. For example, mode letter P/S/M will not dim down as flash icon.
- You can't just throw in bunch of stuff on a viewfinder and expect people to frame their shots properly.
- Camera UI is half-assed by some amateurs. I get it they wanted to replicate Pixel and iPhone type of experience but then at least replicate it properly and make it better
- Display is worse in every possible sense compared to 1IV/V I couldn't care that it's brighter it's the only perk that it has over a display on 1IV/V
- Device is wide enough not to be a one hand device but not wide enough to be considered two hands device
I cannot believe they would release a phone with such a half finished camera app. It just tells me it was a last-minute decision to scrap Video Pro. New Camera app doesn't have a single feature of Cinema Pro inside so it's a blatant lie when they said new app is Photo Pro, Video Pro and Cinema Pro combined into one. It's not! Not even all Photo Pro features are in there and there is no single feature of Video Pro and Cinema Pro to be found except the looks
[ This Message was edited by: cool_sauce on 2024-06-15 07:48 ]
Posted: 2024-06-15 08:46:20
Page <  123>
