General discussions : Rumours : SONY XPERIA Rumors 2014
> Topic Locked
Esato Forum Index > General discussions > Rumours > SONY XPERIA Rumors 2014 Bookmark topic
Page <  123 ... 615616617 ... 621622623>
ascariss Posts: > 500
On 2014-12-07 23:37:26, Velexas wrote:
http://www.techradar.com/news[....]napdragon-810-defects--1275829
SD810 delays?
Qualcomm says 'nope'.
[ This Message was edited by: on 2014-12-07 23:15 ]
of course Qualcomm will deny it, a delay would not be good for the bottom line and would probably hurt the stock. Just hoping a mid march to early april launch for Z4 is still feasible.
Posted: 2014-12-08 07:03:27
amirprog Posts: > 500
I think that the worst thing that could happen is that manufacturers delay the release of s810 devices to april or may and aside of that it's just mobile news drama to get more page views.
Posted: 2014-12-08 08:19:02
nodarsixar Posts: > 500
Amazing
http://www.phonearena.com/new[....]gonal-upgraded-chipset_id63597
Posted: 2014-12-08 11:08:04
XperiaJunkie Posts: > 500
Something is wrong with those slides, it shows the SD805 (APQ8084) in image 1, but in image 2 it clearly says it will be using the SD810 (MSM8994) on other thing , in image 3 the first slide showing the dual speakers, they don't look balanced as the bottom speaker isn't flush with edge of the device but the top one is however that could just be the angle of the image.
[ This Message was edited by: on 2014-12-08 10:49 ]
[ This Message was edited by: on 2014-12-08 10:52 ]
[ This Message was edited by: on 2014-12-08 10:53 ]
[ This Message was edited by: on 2014-12-08 10:54 ]
[ This Message was edited by: on 2014-12-08 10:56 ]
Posted: 2014-12-08 11:47:14
maloqs Posts: 275
Lol the first picture shows that the screen use 5.2 quad hd(barely can be seen).However,i believe huiyi source is more accurate afterall.
Posted: 2014-12-08 12:56:43
huiyi INFO
5.2 INCH 1080P and QHD
Snapdragon 810
20.7MP
IP68
NEW UI
Same
amazing spec, but......................
Posted: 2014-12-08 13:15:15
kurtdean Posts: > 500
@nodasixar
Are you a robot?Sounds like you don‘t have any souls just joking b'ro
Posted: 2014-12-08 13:27:03
Xajel Posts: > 500
Qualcomm might facing problems, but they can deny problems if these problems will not stop them from releasing it in time... there's multiple scenarios that they can deny but still there's problems
1- Limited quantity : Having small quantity will not stop them from releasing it on-time this happens with low yield manufacturing as the design will have too much defect's cores... the working SoC wont be enough to cover the demand, we might have limited quantity even with phones, some manufacturers might release it in a region first and delay the release in other regions... Sony had this scenario before with Xperia arc where they delayed the release for MENA and Australia for about 6 months...
2- Over heating/high power usage : While this might seems hard to fix, they might actually release it, but manufacturers will not adopt it like what happened to Tegra chipsets as they were power hungry limiting the design wins...
3- lower clock than expected : While as mentioned before, clock speed doesn't equal performance, the core design might have higher IPC than other designs making a 2.0GHz works as fast as a 2.7GHz older design... we're seeing this with Apple design... we know that A57 cores ( used in S810 ) has higher IPC than A15, but we don't know how much yet, I mean if we compared a 2.7GHz A15 core, will a 2.0GHz A57 be enough or we need more like 2.5GHz so a lower clock might not be a problem, BUT, if it was very low that it will have lower performance than previous gen. then here's a problem... if we need a 2.5GHz A57 core to equal a 2.7GHz A15, but the design maxes out at 2.1GHz or 2.2GHz then it's a problem... manufacturers will move to the fastest, which in our case will be the 2.7GHz SoC ( the 805 which is not A15 )
Posted: 2014-12-08 13:27:33
On 2014-12-08 13:27:03, kurtdean wrote:
@nodasixar
Are you a robot?Sounds like you don‘t have any souls :lol: just joking b'ro
:D
Posted: 2014-12-08 13:28:36
Velexas Posts: 29
4GB of RAM should be a must-have for SONY to be competitive in 2015. Specially featuring a SD810. Don't you agree?
[ This Message was edited by: on 2014-12-08 20:18 ]
Posted: 2014-12-08 14:26:50
New Topic   Topic Locked
