Regional : Asia Pacific : Finally! Free and Fullfledged gprs using Airtel Prepaid(India)
< Esato Forum Index > Regional > Asia Pacific > Finally! Free and Fullfledged gprs using Airtel Prepaid(India) Bookmark topic
Page <  123, 456 ... 604605606>
kosmonov Posts: 0
actually this trick worked in both of my handsets...i use s60 based mobile called sendo-x & a motorola c350 ..but personally i always used c350 as a modem ever since i used postpaid gprs (long time back)..now too i prefer moto c350 coz its a good usb modem..try it out guys..cheers
Posted: 2006-01-14 11:01:18
rahul11 Posts: 2
my phone is 6230 how do i configure it?pls
Posted: 2006-01-14 18:14:49
raj7650ace Posts: 0
Well Spartan You Really did a hellava job
Well done. And if no one knows and u discovered this flaw..
I did like to propose as
"Spartan's Airtel GPRS"
what do u say folks?
Thank You
(I did My step no.10 )
Posted: 2006-01-14 19:21:20
spartan117 Posts: 3
Configuration for NOKIA 6230 mobiles (Please delete all previous accounts)
1) Press the [Menu] key
2) Scroll to [Settings] and press [Select]
3) Scroll to [Configuration settings] and press [Select]
4) Scroll to [Personal Configuration Settings] and press [Select]
5) Press [Options] and scroll to [Add new] and press [Select]
6)Scroll to [Account name] and press [Select]
7) Scroll to [Account name] and press [Select]
Enter [Airtellive1] then press [OK]
8 ) Scroll to [Homepage] and press [Select]
Enter [http://live.airtelworld.co.in] then press [OK]
Note: Use the [*] key for all symbols
9) Scroll to [Access point settings] and press [Select]
10) Scroll to [Proxy] select [Enable] Scroll to [Proxy address] and press [Select]. Enter [100.1.200.99]
11) Scroll to [Proxy port] and press [Select]. Enter [8080] then press [OK]
12) Scroll to [Data bearer] then press [Select]
Scroll to [GPRS]
13) Scroll to [Bearer settings] and press [Select]
Scroll to [GPRS access point] and press [Select]
Enter [airtelfun.com] then press [OK]
Note: Use the [*] key to get a [+] ]
14) Scroll to [Authentication type] and press [Select]
Highlight [Normal] then press [Select]
15) Scroll to [User name] and press [Select]
Enter [blank] then press [OK]
16) Scroll to [Password] and press [Select]
17) Scroll to [Display terminal window]
Highlight [No] then press [Select]
18) Press the [Back] key twice
19) Scroll to [Active service settings] and press [Select]
Highlight [Airtellive1] then press [Activate]
In the same manner create a second account with name Airtellive2 ,but DO NOT follow Step 19.
Once you finish this the mobile will be set to use the first (Airtellive1) account.
Connect your mobile to the PC , install the modem drivers and enter the following in the 'Extra Initialization Commands' window
at+cgdcont=2,"IP","airtelfun.com"
Now the PC is set to dial the second account on your mobile.
Read my first post for subsequent steps.
Hope this works
[ This Message was edited by: spartan117 on 2006-01-14 18:44 ]
[ This Message was edited by: spartan117 on 2006-01-15 14:12 ]
Posted: 2006-01-14 19:40:41
spartan117 Posts: 3
Thank You
Dear raj7650ace,
Thank you very much
Hum... "Spartan's Airtel GPRS" ,sounds really cool
Wonder what the Airtel folks will think of it
[ This Message was edited by: spartan117 on 2006-01-15 04:56 ]
Posted: 2006-01-14 19:56:57
kosmonov Posts: 0
these airtel masters of confusion used to irritate me a lot wen i had postpaid gprs..now it is my time to get back at them..
Posted: 2006-01-15 07:24:12
rahul11 Posts: 2
sorry but with that number it says cannot initialiase modem.i use datacable.pls dont mind.thanks for the settings.
Posted: 2006-01-15 08:50:37
spartan117 Posts: 3
Exactly my thoughts
By the way , can you guide those users with NOKIAs. How did you make the PC dial the second account ?
Posted: 2006-01-15 15:00:37
spartan117 Posts: 3
Hi rahul,
I am extremely sorry. The initialization command was wrong
The correct one is
(remember there are no spaces between anything).
This works with my Sony Ericsson F500i.Try it and see if it works.
Posted: 2006-01-15 15:20:12
blu_6779 Posts: 193
is this bangalore-specific because it doesn't seem to be working for me
Posted: 2006-01-15 15:48:34
