Sony Ericsson / Sony : Software, Firmware and Drivers : FOTA "Firmware update over the air"
ok it works now, it says mines has latest software which i persume it has, since phone is only out
Posted: 2006-04-27 10:07:44
Is the firmware R4CF002 the latest release on the UK W810i? Device Management says my phone has the latest software... ?
Posted: 2006-06-29 01:59:45
I really want to know why the FOTA service says that my firmware is up to date (mine is a W810i R4CE012)? cos I see here that there are newer versions of firmware already out...
[ This Message was edited by: muskeetu on 2006-06-30 18:19 ]
Posted: 2006-06-30 19:18:16
My FOTA also says that the phone is up to date, however it shows firmware which is old compared to ones listed on the internet.... are they country specific???
Posted: 2006-07-01 00:12:34
Has anyone got this to work on a K750 and it actually shows correct firmware info unlike on those W810s?
Posted: 2006-07-01 00:54:55
is der any new version of firmware available for j300i
n w550i
what wil happen if the updation stops in da middle due to network failure or due to battery low
Posted: 2006-07-01 02:28:35
This is not working like it should. I got my K750 yesterday & it has old R1B firmware. I went to device mgmt. & added the account. It connects using http not https but goes 2 processing step 8 and fails. Tried many void & blank combinations. What's wrong?
Posted: 2006-07-02 20:25:41
Didn't work with my K750 either...
Posted: 2006-07-26 15:27:54
One thing to note; the settings under "Device mgmt" is not related to the remote firmware update service. It is used to remotely update the "OTA" device settings. If this account is setup you can automatically update your device settings (Data accounts, MMS accounts and so on) by pressing "Start". This of course only works if you operator(or somebody else) provides this service.
The remote firmware update uses whatever Data&Internet account that is setup for browsing.
Posted: 2006-07-26 16:22:35
last week and before, when i try the 'Menu -> Update service -> Search for update' my K800i just rebooted. But then this week, it doesn't do the reboot but instead a pop-up says 'Device mgmt. SonyEricsson Session failed'.
[ This Message was edited by: boompang on 2006-07-30 21:08 ]
Posted: 2006-07-30 09:51:51
