Sony Ericsson / Sony : Software, Firmware and Drivers : Raider camera driver for K790, K800 and K810 (v6.6.5)
eventually came this supermode camdriver. Thanks!
Posted: 2008-05-29 17:42:27
ahil13, oh yes
For learning its easy
its like supermode v0.1b
Tryed to set ISO then to take pic but flash dont fire, can we set and ISO for xennon or not?
Posted: 2008-05-29 17:53:31
On 2008-05-29 17:34:42, ahil13 wrote:
On 2008-05-29 15:43:06, sacirxposed wrote:
hOW TO SET SHARPENESS?????
i also think that sharpess is useful unlike zoom. Who is using this digital zoom?
btw when i learnt the ev_functions for 0.1 beta.. now i need to learn this one for the real supermode cameradriver
digital zoom is actually very useful - not for taking a picture with zoom, but using zoom to set your shutter speed. sometimes when you are taking a picture with manual settings and the scene is complex, it is difficult to figure out what shutter speed to use. i often use zoom, to zoom into object that i want to capture in a scene and then manually change shutter speed, till the object i want to capture appears best on the screen. it is easier to do this when you are zoomed into object. i then zoom out and take the picture, hopefully capturing the object with the best possible shutter setting. you can only do this with static objects (obviously) when you have time to frame a picture.
@Raider
congats on new driver. damn i'm going to have to upgrade my w810 now!
Posted: 2008-05-29 17:54:37
I have not tested this driver yet but I had the same issue when I putted xenon ISO and normal ISO together in my beta.
[ This Message was edited by: jomateixa on 2008-05-29 17:00 ]
Posted: 2008-05-29 17:57:11
Auto, daylight wb
[ This Message was edited by: milan91 on 2012-10-25 16:52 ]
Posted: 2008-05-29 18:55:57
What the hell is this????
Posted: 2008-05-29 19:04:33
First maybe helpful picture exchange:
From
to
Will not win a gfx-price but can help in the learning phase...
It's readable and working.
Modding the Zoombar is now somehow different as the values are not spanned to the whole range of the bar, they use different ranges beginning from left. I'm thinking....
[ This Message was edited by: pietropizzi on 2008-05-29 18:14 ]
Posted: 2008-05-29 19:06:04
Maybe to exchange help picture(when press 0) with that picture with EV settings
http://www.flickr.com/photos/milanche91
Ericsson 628>3210>3310>3410>3510>siemens mc60>K750i>> 2x nokia 6630>>w810i>>:es: K800i modded to max
[ This Message was edited by: milan91 on 2008-05-29 18:15 ]
Posted: 2008-05-29 19:14:45
Of course we can, I thought about that too but without loosing the normal help buttons.
There are many options how to achieve that SM-helpscreen, even in the modded Zoombar too. But seeing the different slots while setting EV seems logical.....
[ This Message was edited by: pietropizzi on 2008-05-29 18:19 ]
Posted: 2008-05-29 19:17:01
sacirxposed
this is your M2 problem. if you're trying to say that driver is source of this problem than relax - it's not. driver don't have access to file I/O operations on your memory. I have 2GB M2, photo counter is ~4000 without any problems
milan & joma
ohh, that's simple:
1. ISO value is used in AutoExposure calculations
2. calculated AE value is then used by driver to check if flash fire is needed
if we are in a dark place automatic ISO is high. if we manually set ISO to low value then calculated AE value will be high (which means good light but it's not true). in this case driver will say: good light? fine! there will be no flash fire
there is a simple solution to fix this (added to my "to do" list)
cronos555
haha! now you know what is the next phone which you should buy
Posted: 2008-05-29 19:18:25
