Sony Ericsson / Sony : Software, Firmware and Drivers : Raider camera driver for K790, K800 and K810 (v6.6.5)
On 2008-05-29 21:26:44, hfmls wrote:
its too pro like
... i'll wait for shitty newbie pics patch and maybe i'll try later
i will try it... still dont know the meaning of iso speed and stuff. got read.
anyway, thank you for all u'r great work.
search wiki
http://www.wiki.com/
high iso and quick shutter can be used for freezing raindrops etc,
low iso and high shutter can be used to create a motion effect of for low noise nightpics.
Posted: 2008-05-29 21:34:37
hfmls
I'm not forcing to use it
and it's not a 'pro' only, I don't know why people are still thinking in this way. this code can work as normal driver, optionally you can even enable manual focus and enhanced mode. I know, I must explain customization
number1
tomorrow I will explain a bit
Posted: 2008-05-29 21:45:20
number1
ok thanks, if you could explain the basics i'm sure i'll get the hang of it.
i understand it a bit bit's are similar to the old k750/w800 em code, your driver has been teaching me polish though
dokument = document
makro = macro
manualny = manual
kompresja = compression
scena = scene
informacje = information
stabilizacja = stabilizer
rejestry = registry
neutralny= neutral
efekty= effect
focusa= focus
operacje= operation
portret = portrait
i didn't use a translator just logical thinking some look like the english words just spelt wrong.
Posted: 2008-05-29 22:15:05
sound complicated... @@ besides... the vkp patch can apply on all type of main?
[ This Message was edited by: eddie2020 on 2008-05-29 21:43 ]
Posted: 2008-05-29 22:42:29
I'm loving this driver.Raiderski YOU'RE THE MAN
Posted: 2008-05-29 23:11:55
Raiderski
The flash fires two times after any manual shutter setting.
Posted: 2008-05-30 00:16:07
number1 Polish lang is much more different than English and much more harder. English says document(s) in every situation. Polish says dokument, dokumentu, dokumentowi, dokumentem, dokumenty in different situations
It isn't as easy as U think
That's why most Polish know English and not many English know Polish
T300->T610->E398->K700->MPx200->3xK750->N70->K800 + PSP 2004 3.93 M33
[ This Message was edited by: jokamaciek on 2008-05-29 23:23 ]
Posted: 2008-05-30 00:21:59
Jomateixa
yep, I noticed this some time ago but thanks for pointing this out. tomorrow will be fix
Posted: 2008-05-30 00:27:03
jokamaciek
But Number1 is a genius and now he knows polish, what's up?
Just joking
Raider
O.K.
[ This Message was edited by: jomateixa on 2008-05-29 23:30 ]
Posted: 2008-05-30 00:29:43
On 2008-05-30 00:27:03, Raiderski wrote:
Jomateixa
Oh, I thought that this was intended to allow more light to reach the sensor.
Posted: 2008-05-30 01:04:38
