Manufacturer Discussion >
Samsung
> Problems with screen on sgh-u600
No probs
All you will need is a small + head screwdriver to remove the 15 screws and a small - head screwdriver for lifting parts off.
Posted: 2010-01-26 00:21:46
Good:D
Posted: 2010-01-26 00:22:21
One other thing. The top section plastic around the screen, top keypad is just stuck down and can be gently lifted away if you want to replace that. It doesnt remove the top plastic of the screen though. You have to strip the phone to remove that part.
Posted: 2010-01-26 00:25:42
No, I just wanna fix the cable:P
Posted: 2010-01-26 00:27:31
