Sony Ericsson / Sony : Windows Mobile : What is the latest Xperia X2 firmware
< Esato Forum Index > Sony Ericsson / Sony > Windows Mobile > What is the latest Xperia X2 firmware Bookmark topic
Page <  1234>
bob2k4 Posts: 98
well i've installed the update and i'm more disapointed than i was before!
for one the new dialer looses the 'smart dial' abilities of the old one
and they have still failed to fix the notification errors!
Posted: 2010-03-01 04:02:18
iopy Posts: 37
look one more tim, the smart dialer are still present on my device
Posted: 2010-03-01 12:18:46
amdx2 Posts: 38
just updated it.. i have to say the dialer looks much better easy to use.. and seem a little faster..
Posted: 2010-03-01 13:13:32
bob2k4 Posts: 98
Might just be me then, but I can't seam to find it.
Posted: 2010-03-01 14:38:07
nirave Posts: 203
Found the phone is generally a lot more stable right now with this new update.
However, have found both before and after the update that both my tomtom and co-pilot won't pick up the gps unless using gps gate. And the new update causes gps gate to crash every half hour or so.
Anyone else's sat nav progs running ok?
Posted: 2010-03-01 22:44:53
iopy Posts: 37
After entering phone mode, press the "phone book" symbol, and then press the top of your screen, where you can enter text, then I think you find what your seeking?
Posted: 2010-03-01 23:12:43
doministry Posts: > 500
It's not a smart dial.
Smart dial means you just enter a first and second letter/number in
phone dialer and it automatically suggests you names to dial.
Posted: 2010-03-02 16:35:38
iopy Posts: 37
But that is exactly what my Xperia X2 does. If you're using the tilewave panel, just hit the phone book icon, and then press the numeric keypad that pops up on the screen. You can enter as many letters, ore numbers you want, and the phone will suggest as you press.
Posted: 2010-03-02 23:24:36
Okay, I still don't have X2.
Anyway I was referring to DialPad, not panel.
Also the new .cab update from SE changes the dialer and
I saw on the video how it works.
Posted: 2010-03-03 13:44:19
iopy Posts: 37
It does the same ting when you enter via dial-pad, but there you have to go to the phone book to activate the smart dial.
Posted: 2010-03-03 15:25:36
Page <  1234>
