Manufacturer Discussion : HTC : HTC CEO given 'One' last chance
< Esato Forum Index > Manufacturer Discussion > HTC > HTC CEO given 'One' last chance Bookmark topic
etaab Posts: > 500
Because they use lower quality materials. HTC have always been a budget OEM. Its only this past three years they've tried to bring their name to the front. It doesn't matter how sleek and sexy they make the One look, its still lower in hardware quality than other manufacturers.
Look at the Galaxy S4 internals, tightly packed cutting edge hardware that hardly uses up much space in the phone leaving plenty of room for the battery:
and then we have the One, with its older looking internal hardware. They need about 10 times more silicon just to compete with the S4.
If you compare the images of from Nokia's complaint about HTC using their microphones, you can see from the image Nokia's architecture looks modern, HTC's internals look packed, misaligned and lesser quality. Samsung manage to fit all their hardware into a small section of the phone. HTC require the entire phones length.
[ This Message was edited by: etaab on 2013-05-05 22:29 ]
Posted: 2013-05-05 23:25:51
Bonovox Posts: > 500
Yes,and HTC One and One X are two of the hardest phones to open and fix
Posted: 2013-05-05 23:33:00
Tsepz_GP Posts: > 500
Here's the image Etaab is talking about, the One looking seriously untidy:
Posted: 2013-05-05 23:46:25
Those mics were made specifically for Nokia that's why they got annoyed about it.
Posted: 2013-05-06 00:34:00
itsjustJOH Posts: > 500
That mic looks like a spare from a junk shop. And bomb terrorists would have made a better looking bomb than that phone's internal.
Posted: 2013-05-06 04:43:38
It's not how it looks it's how it's all laid out. Doesn't matter what a mic or chip looks as it's not seen inside the phone. It's how it performs
Posted: 2013-05-06 10:42:00
Supa_Fly Posts: > 500
Etaab is talking about 2 different things "still lower in hardware quality" & "lower build quality" and they're not synomous with one another - if it was Samsung would never have been successful using cheap plastic with SGS/SGS II.
I was under the belief, that HTC has for a number of years, possibly even pioneered higher quality materials ... as we can see from the images you've posted, its about build quality - at least internally where nobody seems to see nor care. However, beauty is skin deep as the saying goes and well looks like their chips are not shielded which is a BAD thing ... subject to call, reception, and performance issues over the first year of ownership alone. To be honest I think HTC is the only manufacturer that doesn't shield their chipsets; a foolish move.
Tsepz_GP, your explanation makes complete and chronological sense ... many thanks!
Posted: 2013-05-07 23:57:21
hibiskus Posts: 65
HTC had great progression with their windows mobile devices, which made peak when they included android and made Desire, HD2 and wildfire line. Sense was 2 lenghts in front of competition, Desire was wan one first phones with Amoled screens, no one cared that much about camera quality, HD2 was super quality phone and wildfire was android for masses.
Every single line after that was fail, and felt like unfinished product. Desire HD, Wildfire S, EVO, Sensation, Rhyme... you name it, and competition was gaining on them. With One X and One they focused on camera department, which ended as worst flagship camera, compared to competition, in One X case and laughable ultrapixels which are not far from SE k750
Posted: 2013-05-08 09:14:59
etaab Posts: > 500
That's the one yes. Just look at that tiny cable connecting one circuit board to another. A better design would not make such a thing necessary. The only time I expect to see cables in something so small as a mobile phone is when connecting two parts which move independent from each other such as a clamshell, or when two circuit boards are spread far apart and a cable is the best solution, as in the SGS 2, 3 & 4 design. What is the length of that cable in the One ? 0.5cm ? probably.
HTC phones are lesser quality than Samsung / Sony / Motorola / Nokia phones and always have been in terms of cosmetics but also the internals.
Remember 2011's Sensation and its antenna located in the rear cover with gold contacts ? the only other phone I know of that has that in more recent times is the Lumia 710. That is always a bad design imo.
I also remember seeing a teardown of my Nokia N8 back in early 2011 which showed its aged internal hardware (in comparison to Android hardware) compared to HTC's phones. At first I thought the difference was because Symbian running phone required lesser hardware which was easier to fit in a small design, but now I realise it was because Nokia know how to make quality hardware that the consumer does not see. HTC phones are very badly designed internally.
Posted: 2013-05-08 23:30:00
