Sony Ericsson / Sony : Android : Xperia XZ Announced
< Esato Forum Index > Sony Ericsson / Sony > Android > Xperia XZ Announced Bookmark topic
Page <  123 ... 6566, 676869>
doministry Posts: > 500
Any issues? Any news?
Posted: 2017-04-25 13:45:39
McKinley Posts: > 500
Yes the icons have an up-to-date material look. Other than that I don't know what's new.
Posted: 2017-05-08 17:56:17
Got all the updates. The new things are small but useful.
Like a little darker backr for SMS.
Or improved multitasking.
Posted: 2017-05-10 17:17:10
On the latest .223 FW I have an annoying problem with Google Maps:
The voice is out of sync with the map. It's terrible.
If's like saying commands few hundreds meters before I get there.
Anyone?
Is it Xperia issue or the Maps itself?
Posted: 2017-05-25 02:55:51
moogoo Posts: > 500
Sounds more like a maps issue than Xperia. As long as your GPS position is correct I'd try updating the app or changing your settings. There is a navigation setting for voice command sensitivity and when it the commands happen. Maybe try look at that?
Posted: 2017-05-25 06:52:56
I am not sure which sensitivity you're talking about?
Posted: 2017-05-25 12:17:55
moogoo Posts: > 500
my fault dom... i thought i remembered a setting where you could tell google to only prompt when it was within 500 feet instead of miles. or something like that.
anyway, i still think the issue you're having is most likely app related. i'd try updating or uninstall-reinstall. sorry for the confusion.
Posted: 2017-05-25 18:23:39
All of the sudden I have battery drain issue.
I hate this. I don't have any strange apps running in the background.
It's random, happens sometimes.
Anybody??
Posted: 2017-05-30 09:59:38
Just for the record, the drain issue is gone - it was probably Google Services in the background.
After killing it for a moment all is back to perfect.
The GoogleMaps issue is reported by multiple users in PlayStore.
Posted: 2017-06-01 15:16:59
New update available 41.2.A.7.8.
Posted: 2017-06-24 10:55:29
