Sony Ericsson / Sony : UMTS / 3G : Orange 3g sim
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > Orange 3g sim Bookmark topic
imanuk Posts: 241
@darrengf it was a orange boxed and branded p900 I dont claim to understand. I was on a orange premier staff package tho - who knows!
Posted: 2006-11-15 16:50:49
Phoenixrises Posts: 6
O2 also only give out 32Kb SIM's unless you specifically ask them.
Orange WILL give you the SIM as long as you get onto customer retentions. and while your at it, tell them Voda will give you a 3G SIM, double minutes and 5 Megs of data at half the price plus 1000 free texts.
see how high they jump then..
Posted: 2006-11-20 21:48:51
And there is no such thing as 2.5G
there is
1G (1st gen) Anologue. (anybody else remember that?)
2G (2nd Gen) GSM (all of it, EDGE and everything)
3G (guess??) UMTS, CDMA 1x RTT, TDSCDMA etc...
no halves..... GPRS is a protocol, nothing else... same as AMR, half rate coding, HSDPA/ UPA...
Tak.
Posted: 2006-11-20 21:55:41
thelight Posts: 70
first off, what is customer retentions? I dont recall hearing that menu option
second, I dont know the semantics or specs of each protocol, 2.5g/3g is what the register call the 2 things, and that is the only place I really read about mobile phones, I think people got the idea of what I meant though.
Posted: 2006-11-20 22:03:40
imanuk Posts: 241
@Phoenixrises 2.5g is not a 'real' GSM standard but the frequently used term to descibe things like GPRS that was added to the 2G spec to bridge the gap until 3g as i understand it.
Posted: 2006-11-22 16:03:28
Bchambers Posts: 10
On 2006-11-14 09:12:20, lovewalrus wrote:
I'm really suprised they can't just activate 3G on your account-they must be givin out really old SIM cards and not the 64k one's most other networks have for last few years to avoid this problem!
<br/><br/>
<i>This message was posted from a K800i</I>
A 3G is more then 64k if you look on a 2g sim most start with 894412 then the first numbers are 14 16 or 18 they are called profile numbers the 3G sims are profile 33
Posted: 2006-12-16 21:21:23
thelight Posts: 70
yup my sim starts with 894412 but the next numbers are 21
Posted: 2006-12-16 22:04:56
darrengf Posts: > 500
Orange 3G Sims start at Profile no 23
Orange Normaly will not give you a Free 3g sim card even through retention.
Sorry you have to purchase 3g sim card from the Orange Shop which are £5, When you ring orange customer care (PAYG) then they will change your profile over to the new simcard.
If you are on Contract then you will not get a 3g sim card no matter what unless you purchase a 3g phone from Orange.
Orange has a policy that the Sim Card belongs to the phone. So if you are on contract and buy a 2g phone then the sim is registered to use all the services on that phone correctly. They are not saying that the sim card wont work in other phones but you may not be able to use all the functions.
3 have the same policy
vodafone and o2 work on a different system and will alloy you to obtain a new sim card for free (This is not always the case tho and its done on a person to person basis)
T-mobile and Virgin have both been very clever, All there sim cards have been 3g active for the last 3 years (Even tho there was no network) all you need to do i ring them and they will activate it for you. (Saves on simcards, costs and hassle).
Yes I also agree that for the network sake put 3g ready sim cards in all the phones, This then will save the cusotmer, network, cost, enviroment and time for every one, The cusotmer is happy and network are happier asthey get the revenue from it.
However Orange dont see it like that. As Orange phones are now very heavy in there own crap branding then you are bound to use there services through the phone which gives them the revenue back quicker.
I will let you int a little of inside info, Customer care hate the Orange branding phone and buy the phones sim free or from 02 on a contract with them.
Posted: 2006-12-17 01:47:27
Dj Boyi Posts: > 500
i have an orange 3g sim in my w810i as i upgraded to get a z610i for my mum,the number on the sim starts wiv the usual 894412 but then the next 2 numbers are 13,i'm gettin confused now
Posted: 2006-12-17 02:29:31
@Dj Boyi
That may be the case.
The last i was told that orange was using 23 but 13 sounds about right.
13,23,33 (3) seems to indicate a 3g location base station
Posted: 2006-12-17 02:42:08
