Sony Ericsson / Sony : UMTS / 3G : Gmail on V800
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > Gmail on V800 Bookmark topic
Page <  123>
Dragonfly_TP Posts: > 500
Okay I'm setting up gmail on the V800 now. After setting up incomming port it says someting in dutch (I have the menu language in dutch) "Codering" or coding in English. When I select that, I can set SSL for incomming and outgoing server, but it also asks for a Domain, what do I fill in there or is it not neded?
Posted: 2005-03-16 09:34:34
I get the following error upon connecting to the mail server: TLS/SSL bad certificate
Posted: 2005-03-16 09:46:51
okay it is not easy to setup gmail on the V800
further more I miss the option to turn on authentication for the outgoing mail server, or as alternative you can use the authenticated server of vodafone. (authsmtp.vodafone.nl in my case) this works on my pda.
Posted: 2005-03-16 09:52:25
Okay my last message and I sigh...
I spoke to technical support (2nd line support (me is only 1st line )
Okay they will try to setup gmail incomming server on the V800
Outgoing is not going to work, but you can send via outgoing server of vodafone
I want a chocolate covered, chocolate chip, chocolate cookie!
[ This Message was edited by: Dragonfly_TP on 2005-03-16 09:10 ]
Posted: 2005-03-16 10:07:28
Vlammetje Posts: > 500
the domain should be pop.gmail.com I assume that's what you filled in.
With Vodafone it's mandatory to use authsmtp.vodafone.nl from your phone so forget about gmail smtp
Now the big question is: Can you receive your mail?
[edit] bah to vodafone!
!! My V800 Theme Making Tutorial !!
V800 Theme Creator
[ This Message was edited by: Vlammetje on 2005-03-16 09:11 ]
Posted: 2005-03-16 10:09:23
well on my pda I can use the authenticated server of gmail because my pda supports authenticated connection. When sending and receiving mail I get a server certificate invalid error and choose continue anyway and I send mail and I receive mail.
This just doesn't work like that on the V800...
[ This Message was edited by: Dragonfly_TP on 2005-03-16 10:23 ]
Posted: 2005-03-16 10:29:35
well i do not get the 'invalid certificate' message, my phone crashes when downloading mail... when there is no new mail it doesn;t crash
Posted: 2005-03-16 10:36:10
Bobajobbob Posts: 41
I can confirm to the doubter above that I have enabled Pop in my Gmail settings.
Posted: 2005-03-21 14:52:00
That was me mate
Posted: 2005-03-21 14:56:04
philip Posts: 2
Settings for V800, GMail and Vodafone in Ireland
Connect Using: Vodafone Mail
Protocol: POP3
Incoming Server: pop.gmail.com
Incoming Port: 995
Encryption:
Incoming Server: TLS/SSL, Domain: pop.gmail.com
Outgoing Server: No encryption
Mailbox: username@gmail.com
Password: gmail password
Outgoing Server: mail.vodafone.ie
Outgoing Port: 25
Email Address: username@gmail.com
Download: Headers only (or whatever your preference is)
From Name: Your Name
Signature: Can leave blank (or whatever your preference is)
Copy outgoing: Off (or whatever your preference is)
Check interval: Off (or whatever your preference is)
I couldn't get the smtp.gmail.com for the outgoing mail server working, so I have just used Vodafone's one here. If anyone figures that out maybe you can post it here. Anyway, this is pretty good, as you can check your gmail and send replies (even if it is going through Vodafone).
Cheers,
Philip
Posted: 2005-06-22 14:16:01
Page <  123>
