Sony Ericsson / Sony : UMTS / 3G : Misc V800 questions
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > Misc V800 questions Bookmark topic
UnholySinner Posts: 122
hey guys, i have tried to upgrade my phone and have gone as far as holding the left cursor and switching the phone on, then my problem occurs... it asks me to verify where a "USB FLASH" is. As described in an earlier post, i tried directing it to the Installation CD, and also to the Sony Ericsson Update folder which was installed during the update process. I just cannot find the FLASH USB. Do i get it from anywhere else? I connected the phone with the USB cable that came with the phone, do i need a different one?? Please help!
Posted: 2005-04-04 21:54:41
... SUCCESS! Found the USB FLASH driver on a link (trying to get to it through SE website didnt work, it was down) then carried on with instructions, had 1 or 2 Failed attempts, worked when i took my sim card out though, duhh!! Thanks everyone anyway!!
Posted: 2005-04-04 23:24:42
whoami Posts: 29
It works with software called R1x016 as well!!
On 2005-03-25 20:35:39, Pallister wrote:
Hi! Original V800 software doesn`t support Picture ID on the external screen mate.
You have to update your software..
By pressing >*
The newest software for decustomisaton from V800 to Z800 is called R1x019...
This software supports Picture ID
Posted: 2005-04-05 00:08:16
