Sony Ericsson / Sony : UMTS / 3G : New Firmware for Z800 / V800 on total-multi-server is R1AB013
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > New Firmware for Z800 / V800 on total-multi-server is R1AB013 Bookmark topic
Page <  123 ... , 111213>
DIFference Posts: 41
[ This Message was edited by: DIFference on 2006-02-21 04:06 ]
Posted: 2005-09-07 12:13:22
Strider420 Posts: 112
I tried the two pics and the difference is noticeable. There are artifacts on the JPEG because of the compression while PNG files are not compressed. That is great for something like a graphic with not very many colors but for a sceneery, the png file size would be a lot bigger than the jpg.
Posted: 2005-09-08 17:14:07
Thx, then i know even more that there is mothing wrong with MY phone.
The png file size is smaller than the jpeg file size...
[ This Message was edited by: DIFference on 2005-09-09 22:26 ]
Posted: 2005-09-09 23:25:40
ger Posts: 1
Hi All,
I'm new to SE phones and 3g so I would appreciate any assistance & sugections you can provide. BTW I think the z800 is an awesome phone. I have a couple of questions:
1. How do you know if you need to update your frim ware?
2. What excatly is firm ware?
3. How do you update the firm ware?
4. What are the benefits if any?
As you can probaly tell i am a not that IT competent.
Thanks
Posted: 2005-09-10 07:23:56
On 2005-09-10 07:23:56, ger wrote:
Hi All,
Thanks
1. If you have any problems and bugs in your phone you should upgrade to the newest one. The newest one is called R1AB0014. The one before that one is called R1Y005. You can find out which firmware you have by pressing *>* = right)
2. It is an upgrade software for the software in the phone. Like service packs is for Microsoft Windows.
3. Either you hand it in to a Sone Ericsson Service Partner, to the place where you bought it (they send it away for upgrader) or you do it voer the internet (doesn't work for me).
4. Benefits are hopefully fewer bugs and maybe some upgraded features.
[ This Message was edited by: DIFference on 2005-09-10 15:45 ]
Posted: 2005-09-10 16:43:53
Anger Posts: 37
I bought the V800 last friday and it has installed the R1AF005 which I tried to update via SEUS that says it is the last firmware for my phone.
So R1AF005 IS the latest firmware for Sony Ericsson V800.
Greetings,
Anger.
Posted: 2005-10-04 11:37:38
pji Posts: 1
I just converted my V800 to a Z800i using TMS but when I turn on the phone I get a configuration error. Any advice?
Posted: 2005-10-04 22:36:16
saintsimon Posts: 4
On the latest TMS Version there is the (Red-Cross) 'Repair/ Reflash Phone EROM'-Button. Use that to revitalize the phone, it is for free.
Posted: 2005-10-08 03:41:26
erike Posts: 4
Wonder when the new R1AF005 (as mentiones by Anger) will be available on TMS. Hopefully this fixes the very annoying Bluetooth issues that have been plaguing the V800.
Posted: 2005-10-08 23:57:35
skhuu Posts: 88
My firmware is R1S025, I tried to update using SEUS and it says I have the latest Firmware. I tried the TMS, but I have the original usb cable, I think it doesnt work. I have 1 credit with TMS. My phone is vodafone V800 802SE, its not locked.
Can anyone give me the instructions that I must follow and what cable I should use.
thanks.
Posted: 2005-10-09 20:52:00
