Sony Ericsson / Sony : UMTS / 3G : New Firmware for Z800 / V800 on total-multi-server is R1AB013
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > New Firmware for Z800 / V800 on total-multi-server is R1AB013 Bookmark topic
Page <  123 ... 111213
az2k5 Posts: 1
hey
'ANGER', can you set normal MP3s as ringtones on your R1af005 V800?
cheers
az
Posted: 2005-10-30 15:50:49
Vlammetje Posts: > 500
Shkuu, you need a T28 service cable (serial) (cheapest option) for TMS. the USB cable is not supported. Other hardware that is supported can be found on the site www.totalserver.com
It s possible that your R1S is the latest while someone else in another region may have a later fw version available to them via SEUS. They are not all updated at the same time unfortunately.
Posted: 2005-11-02 11:12:53
skhuu Posts: 88
Thanks Vlammetje, will try to get the cable.
Posted: 2005-11-02 20:48:00
Anger Posts: 37
On 2005-10-30 15:50:49, az2k5 wrote:
hey
cheers
az
No. If you want to do that you have to use drmp.exe (Digital Rights Management Packager) from SE.
Have a nice day,
Anger.
Posted: 2005-11-24 18:37:20
