Sony Ericsson / Sony : UMTS / 3G : New Firmware for Z800 / V800 on total-multi-server is R1AB013
< Esato Forum Index > Sony Ericsson / Sony > UMTS / 3G > New Firmware for Z800 / V800 on total-multi-server is R1AB013 Bookmark topic
Page <  123 ... 910, 111213>
sapporobaby Posts: > 500
@Night
I do not have the "i" either but I do not have any bugs as you say. My phone works exactly as a friend of mines does and his a retail z800i. The software you have is very old.
Posted: 2005-08-11 22:28:46
Strider420 Posts: 112
R1X016 is indeed very old. The absolute latest firmware is R1AB014 though anything from R1Y onward should be OK for you.
Posted: 2005-08-11 22:29:02
Hey Strider
Did you use TMS or Davinci to do your phone or is it retail? If you used Davinci or TMS does yours say z800i or z800?
Posted: 2005-08-11 22:30:15
I used TMS and mine says Z800
Posted: 2005-08-12 15:42:58
michael the mage Posts: > 500
Just tried to flash my Z800i unlocked with TMS and after the flash it stopped in the finalize section. Now the phone is dead because it wasn't finalized.
ANybody know if that's a problem with TMS client 1.80 ?
Lost 3 credits and they don't answer back.
ANybody sells credits from them because where I by usually, doesn't answer either.
Thanks
Error code is 0x003242
Posted: 2005-08-14 00:13:33
achua Posts: 3
can someone tell me if i can use my S800i usb cable to upgrade my phone to Z800i. i tried searching but cant find any info. thanx
Posted: 2005-08-14 03:42:14
night_66 Posts: 202
Hi again ..
I went to the mobile store again telling about the problem i mentioned earlier about the old software ..
He updated my phone with newer firmware which is: R1Y005 !!! He said this is latest he can get.. he dont use TMS or Davinci ..
Now my Z800 works great .. and have no known bugs yet ..
The most cool thing in what i got with this software.. that i can choose the kind of network for my Z800 . .if its GSM + 3G or only GSM !!!! this was not enabled since i bought my phone ! its really cool !! so the place i have bad 3G coverage i can set my phone to be a GSM phone only !! and in good places there is 3G coverage.. i choose GSM + 3G.
I found this setting like that ..
Go to SETTINGS, then CONNECTIVITY .. then MOBILE NETWOKRS ... then GSM/3G Networks .. there i can choose between:
GSM and 3G
or
GSM ONLY !!!
Its damn cool and very flexible option !!! i love my Z800 more now
Posted: 2005-08-14 03:45:08
On 2005-08-14 03:45:08, night_66 wrote:
Hi again ..
GSM and 3G
or
GSM ONLY !!!
Night,
Hate to tell you this dude, but this functionality is not new. I have been doing this when my z800 was a v800i. I flashed it to a z800 via Davinci and have the latest software, R1AB014. The guy that told you R1Y005 is wrong, wrong, wrong. Here in Finland the SE service points are flashing to R1AB014. You need to correct them there.
Posted: 2005-08-14 21:17:02
night_66 Posts: 202
Hi again,
Whats the changes between R1Y005 and the newer version R1AB014 ??
Is it worth to do this upgrade ?? cause i couldnt do that via SE update service via internet !!! I have ( TRE ) operator lock in my phone which does not allow me to upgrade to any newer software with SE website in internet !!
Thanks
Posted: 2005-08-14 22:37:49
night_66 Posts: 202
Dear sapporobaby
I called SE Coustmer Service in Sweden last friday 12th augest , they told me there is NO NEW firmeware to Z800 than R1Y005 !!!!
They said R1Y005 is very stable firmware, but maybe they will have a new verision with small fixes regarding bluetooth usage in Z800 in very new future .. (no date yet for launching it).
When i told them about the newer version in TMS and Davinci .. they said its just third part firmwares and they dont recommend me to use it cause if i do anything wrong .. everything well go to hell and my phone could be useless .
Regarding the option i discovered , when u choose between 3G + GSM or only GSM .. this was DISABLED in my Z800 when i bought it ... its just came lately when i unbranded it.
I think cause *Tre* Three operator in Sweden is not a GSM oeprator, its just a 3G + GSM operator, they even sell only 3G phones !! no GSM phones at all and no one with normal GSM phone can use thier SIM card in thier phones !! Thatīs why it was DISABLED in my MENUs..
Its cool
[ This Message was edited by: night_66 on 2005-08-14 21:55 ]
[ This Message was edited by: night_66 on 2005-08-14 21:57 ]
Posted: 2005-08-14 22:52:27
